Question about NetGear WGR614 Wireless Router
Wep code how do i get this
Paid for connetion to internet i am using a friends at the moment.apparently i need a WEP or WPA code for my connection plse help.
  • 2,794 Answers
Your friend is going to have to give you the WEP code in order to get in.
Posted on Jun 14, 2008
What is the WEP for internet connection
WEP is a standard for wireless internet routers security , not really used anymore as it is very weak replaced with WPA and WPA2 encryption essentially WEP would be the password used to connect to your router but as I have said very outdated defaults nowadays are WPA much safer
Jul 08, 2014 | Video Game Consoles & Games
What is wpa passphrase
If you use wireless WiFi, instead of direct ethernet cable connection to the Roku, WPA passphrase and WEP key are security codes used to keep unauthorized people from using your wireless signal to access the internet and possibly eavesdrop on your internet activity.
Apr 21, 2014 | Roku XD Streaming Player 1080P Wireless-N...
Connecting to Wifi at home. Error Code 51102 What
A WEP key is a Security code but for some wireless providors a WPA-TKIP or WPA"-TKIp is used instead. check your connection details to find out which one yours uses and the use the appropriate settings.
Important notes would be that if your connection is using WPA-TKIP or WPA2-TKIP then the DS or DS lite will not be able to connect because they can only use WEP keys. If the system you are using is the Nindento DSi then all you need to do is to use connections 4, 5 and 6 found in Advanced Conection Settings under the internet option in the DSi Settings menu ( remember this method is only for use with other wireless securities than WEP keys like WPA-TKIP and WPA2-TKIP.)
Apr 03, 2011 | Nintendo DS Lite
My ds lite wont connect to our internet i have a wireless router the ds says the security settings are not supported by the nintendo ds
WPA and WPA2 are not supported by the DS Lite, only WEP and unencrypted wifi connections are. There is no known way at the moment to make the DS Lite support WPA of any form so your only three options are to go to WEP encryption, use no encryption (not recommended), or set up an adhoc connection on a computer with that is connected to your router that has internet connection sharing enabled.
Mar 10, 2011 | Nintendo DS Lite
Error code 51332 unable to connet to internet
Error Code: 51332 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Jul 01, 2010 | Nintendo Wii Console
I have an error code:51330
You got a vista?
For vista:
go to search,type in CMD and then type in:
IPCONFIG/ALL and it will show WEP key,scroll up a bit.
For Windows XP:
go to control panel,and go to Local Internet and then
click details.
or go to
www.nintendo.com
XP is more easier.
Mar 05, 2010 | Nintendo Wii Console
Cannot connect to internet error code 51330 is showing
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Need more info? Check Nintendo's website at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Nov 19, 2009 | Nintendo Wii Console
Wireless laptop finds signal, connects to network but no internet
just a thought but may be you can try to remove the WEP/WPA and select the connection mode based on MAC id, hope it was some help
Jul 23, 2009 | D-Link DIR-625 (790069292637) Wireless...
PSP browser
WEP or WPA are the abbreviations of Wired Equivalent Privacy and Wi-Fi Protected Aaccess. These are similar to password to access to people wireless network. You should have one if you've got internet and wireless network in your house. You can paid T-mobil for Wi-Fi fee ($20.-/mo) and they will give you thru' your T-mobil phone, and you can use your PSP with new WEP or WPA at any WI-FI spots like Starbuck, Barn & Noble....
I hope it heps.
Jun 15, 2008 | Sony PlayStation Portable (PSP) Console
Connecting ps3 to internet
Your wireless router probably has a wep or wpa passcode that you will need to enter into your PS3.
Oct 15, 2007 | Sony Playstation 3 (PS3) Console
NetGear WGR614 Wireless Router Logo
96 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
