Question about Lorex L516321
WHAT IS THE DEFAULT ADMIN PASSWORD FOR A LOREX L516321
I need the reset pass word for a lorex LH0 414 -DP year 09 2016 thanks
https://help.lorextechnology.com/link/portal/57356/57366/Article/1299/DVR-NVR-Default-username-and-password
Nov 23, 2017 | Lorex Home Security
My Lorex home security camera system is showing hacked how can I fix this and what does it mean
You can contact lorex for firmware update and after that change the default password.
Sep 27, 2017 | Lorex Home Security
How do I reset the admin on a Lorex eco2 security system
Might want to call the manufacturer or Google the make and model #.may be able to grab a manual
Jan 24, 2015 | Lorex ECO2 16-Channel Security System,...
Forgot lorex menu login name
Ouch that's a tough one. You will need to go to the lorex console and reset the password for the account you're trying. If you don't have the administrators password, you will need to contact the system admin and ask them or reset the machine to factory defaults and set it up again, this time writing down the administrators password and the passwords for the access accounts you create during setup. It is after all a security appliance and there for pretty ridged. If all else fails, read the manual that came with the system, they're pretty straight forward. If that doesn't work call Lorex support they're a bunch of very friendly guys. They can give you setup help but as it is a security device, they won't help with passwords.
Nov 11, 2013 | Computers & Internet
Lorex password
Should be1234 unless u have changed it
Mar 30, 2012 | Lorex L19wd804251 19 Lcd Dvr Surveillance...
Wanted to set password om my linksys
Reset your router back to it's factory settings by holding the reset button for about 5 seconds.
I have provided a list of the most popular router brands. If it does not work you may need to
google what your specific model's default IP address/default username/default passwords are, for
example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it
can depend on where you obtained your router. If you purchased it yourself from a store then the
standard defaults should work. If you obtained your router from your Internet Provider you may
need to contact your service provider. It also may depend whether it's an old or new model router
as well. And you may need to press and hold the reset button on your router several times before
it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is:
192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or
192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Computers & Internet
New password wifi
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
Sep 07, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
Forgot my password and cannot reset?
Sep 06, 2011 | Computers & Internet
Lorex L516321  Logo
634 people viewed this question
Top Lorex Televison & Video Experts
Colin Stickland
Colin Stickland
 Grubhead
Grubhead
Are you a Lorex Televison and Video Expert? Answer questions, earn points and help others
