Question about Garmin GPS 72 GPS Receiver
Gps 72 system locks up with vertical blue line on screen. cannot reboot until removing power source. Then will reboot but go through the same thing
  • 4 more comments
  • Anonymous Aug 11, 2008
    I have the same problem..
  • godofredo_go Sep 15, 2008
    i dont use it to often,it starts but after 5 minutes it goes out and a vertical line appears ,i have to take batteries to star it again ,but keeps doing it again.
  • ntaylorartis Sep 17, 2008
    I will be on track to a site when my GPS goes blank with only a blue line across the screen. When I take out the batteries and replace them, it will power back up, though I have to start all over to get back to my original reading. It then can go out again at any time. I am so frustrated with my unit, for it is no longer reliable. I need it fixed asap. Nancy Taylor
  • optimum Sep 30, 2008
    If you don,t have the patch cable to connect to PC, and have the fix via Garmin web site downloaded,( cable is approx 34 u.s.d. for the gps 72 ) then you can get around the problem by disabling the wass feature. Quality control messed up on this one. The unit will not shut down or cause further problems with the update installed , or you can simply disable the wass feature and it will work. Unfortunatly the unit will not be as accurate when not in the wass mode.. Go to the Garmin site under updates and downloads and download the web updater. Too bad garmin will not eat the cost of the patching cable due to thier software problem. I went through this with them, to no avail.
  • Anonymous Oct 19, 2008
    I have the same problem on my new Garmin eTrex Vista. Screen goes dead randomly after a few minutes or more of use and have to take batteries out and then put them back before unit responds again and the blue line on the screen goes away. VERY frustrating.
  • cmorse1 Dec 15, 2008
    I also have the same problem
As mentioned before, disabling the wass feature will do away with this problem of the ( DREADED BLUE SCREEN) and having to remove power source then re introducing the power source, only to go through the whole thing again. Or >>> Download the fix via Garmin web site ( free ). You will need the interface cable to transfer the data once download from your computer to the unit though.This cable is approx $ 34.00 u.s.d., and as mentioned on Garmin site, if you screw up the data transfer it will have to go back to factory. The wass feature makes the unit more accurate, but the unit will function very accuratly with this feature disabled...
Posted on Nov 04, 2008
I have had some success by deleting some of the tracks that were stored in the GPS. Mine was at 100% memory full and it was getting the blue line every few minutes, I deleted the tracks and some other waypoints I didn't use and it has been back and working for me. The next one I get will not be GARMIN GARBAGE!!!
Posted on Oct 30, 2008
Download the update program from the Garmin website. Woked for me!
Posted on Sep 28, 2008
Update firmware to 2.50
Posted on Jul 24, 2008
White screen with red blue vertical lines
If the unit was dropped there may be nothing you can do. If you are skilled with electronic repair you may check the circuit board connections inside, but internal damage to the board or screen will most likely be beyond repair. If the unit is fairly new there may still be warranty coverage, check with Garmin.
Aug 04, 2012 | Garmin nuvi 1300 Car GPS Receiver
Reboot the Nuvi 360 to "Mass Storage Mode"
1. Connect Nuvi3xx to PC vis USB Cable for 7xx to go into
mass storage mode.
2. Slide Power Switch to the right (LOCK Position)
3. Click the "Safely Remove Hardware" icon in system
Tray on PC (Lower Right)
4. Click on "Safely remove USB Mass Storage Device -
Drives(x:and y:)" x: = mass storage for the 3xx and y: = the
SD card if one is installed
5. WAIT for 3xx to Boot UP.
6. After 360 Boots UP slide power switch to center
position
Sep 30, 2008 | Garmin n vi 360 GPS Receiver
The screen displays a vertical group of black and grey lines. Won't shut down?
it seems like its in calibration mode
Turn unit off
Slide Power Key to the right ( lock )
Hold your finger on the screen for approx 30 seconds until calibration screen appears
Follow on screen instruction''
Here is a online Manual for your unit that I found .... http://www.retrevo.com/pdf/23127ci168/76/Calibrating+the+Screen#q=Garmin+285WT
Oct 28, 2010 | Garmin Nuvi 285WT GPS Receiver
My gps72 just started going off and a thin vertical line appears on the screen. the onl way I can get to come back on is to remove one of the batteries and then it will turn on again and the problem starts...
You need to update the software version to 2.50. You will need a data cable that connects to a serial port on a computer. Be sure to have fresh batteries in the unit and set it to simulator mode when you turn it on and then update. The update is on garmins website.
Mar 03, 2010 | Garmin GPS 72 GPS Receiver
I have a black vertical line on my lg plasma screen
Reboot the tele system, look for an updated software driver download on the LG web site, try different sources like VCR, DVD, Blu Ray to see if vertical line is there.  If still there, then your tele is fu.k.d in which you should contact LG or replacement or repair.  If you recently purchased this thing, then take it back to the shop and demand an exchange or refund for selling you this rubbish.  Cheers.
Nov 01, 2009 | Televison & Video
Where can I buy a new screen for my Garmin GPS 72
You cant. The best Garmin will do is supply an exchange refurbished gps. Alternatively source a second hand unit from somewhere eg on line with a good screen & swap them over.
Oct 14, 2009 | Garmin GPS 72 GPS Receiver
When the unit turns on all looks well, until the gps gets a position anf then it shuts down (screen goes blank. Is there a way to reboot ther GPS
Is it connected to a power source? If not then it may need to be fully charged and then connected . Many GPS fail due to low battery power or a bad power source.
Jul 22, 2009 | Navman Tracker 5600 GPS Receiver
Problem
uninstall ALL video drivers reboot computer should reboot with standard windows video drivers does the screen still play up if so you may have faulty video card.let me know please
Jul 17, 2008 | ATI Mobility RADEON Graphic Card
Garmin GPS 72 quits running
If you have the serial interface for your 72, go to the Garmin website and upgrade your Software. The latestes version 2.50 has a fix for that. You can find your version by going to the System Info menu.
May 14, 2008 | Garmin GPS 72 GPS Receiver
Screen Blanks
SailorMan,
Contacted Garmin Tech Support and they verified the problem with the WAAS. They said the engineers were looking at the problem. Estimated the fix would be ready in 2 to 3 months. I turned the unit on inside where the unit could not receive any satellites then disabled the WAAS and the unit works without problems. It is just not as accurate.
Oct 19, 2007 | Garmin GPS 72 GPS Receiver
Garmin GPS 72 GPS Receiver Logo
359 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
