Question about Technics Audio Players & Recorders
My tecnics Amplifier Model # su-v98 has no power. I've checked all cords
  • 2,071 Answers
The solution#1 answer is mine,it's happen i forgot to "sign in" thats why my rank is apprentice and guest.I will re write again here down so i get the rating.Try these test,the only common possibility would be the transformer and the power supply if both channels are out.You better to check both the positive and negative voltages from the power supply to see if both are present or if one or both are missing.This would be DC voltages of approx. 20 to 40 volts.The positive voltage must be equal to the negative voltage,with the exception of their polarity. The transformer can be checked for AC voltage before the power supply .This reciever uses a single power supply so the problem would be common to both channels.You better change the regulator and checked some capacitor near the regulator.
Posted on Jun 17, 2008
Try these test, the only common possibilty would be the transformer and the power supply if both channels are out.You better to check both the positive and negative voltages from the power supply to see if both are present or if one or both are missing.This would be dc voltages of approx.20 to 40 volts.The positive voltage must be equal to the negative voltage,with the exception of their polarity.If one higher than the other, the regulator in power supply is busted already.The transformer can be checked for AC voltage before the power supply.This reciever uses a single power supply so the problem would be,common to both channels.You better change the regulator and checked some capacitor near the regulator.
How do i connect a subwoofer to my stero technics su-800mk2 amplifier
You would connect any non-specific subwoofer according to its needs:
passive = to an amplifier channel;
active (self-powered) = per its manual and the capabilities of the source.
Given the lack of a specific subwoofer facility on the SU-800, you need a sub that can be driven by full-range speaker level output. Its manual would describe the procedure. Keeping in mind that most active subs are pretty much the same speaker-level-connection-wise (if they allow it), you could find just about any manual and wit would get you running.
http://archiwumallegro.pl/technics_sua800_mk2_wysoki_model_krakow-998303435.html
Jul 06, 2011 | Audio Players & Recorders
I have a technics amplifier SU G75
I have a technics too, and faced the same problem. The solution is very simple just ensure the +ve and -ve wires are connected correctly for each speaker to the amp. Eg. red wire to the red knob and black wire to the black on both ends. sometimes this arises because the wires are of just one color however there will be some marking on the wire to indicate which is +ve and -ve. This took care of the overload problem.
Jun 18, 2009 | Technics SA-AX530 Receiver
Su-g91
Have you checked the fuse in the unit?
Aug 31, 2008 | Technics SA-AX540 Receiver
Technics SU-C04 Amplifier. Left on for about two days, then radio played pushing power, Kinda loud. Amplifier just quit, then noticed it was HOT. With power to amp, pushing the on / off switch to on, no...
mine had the same problem... turned out one of the big transistors (the ones attached to the heatsink) was dead, got a new one (not the same one but with the same characteristics) and voila! though i didn't actually do it, i left it to a technician xD Good Luck! MicroSeries FTW
Aug 09, 2008 | Audio Players & Recorders
Technics su-v98. Powers on but no sound can be heard, not even through the headphones jack.
Make sure it is not on mute. Check rear of receiver to make sure AUDIO IN has not become disconnected. Check input selector and verify that it matches the audio source.
Apr 03, 2008 | Audio Players & Recorders
110 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
