Dodge Master
- Posted on Nov 05, 2010
Re: How do you get access to the rear turn signal lights...
From autozone.com. Please let me know if you have any questions.
- Release the trunk latch and open the trunk lid.
- Remove the fasteners holding the trunk lining to the lower rear deck panel.
- Separate the trunk lining from the deck panel.
- Detach the lamp wiring from the wiring harness.
- Remove the nuts that retain the tail lamp to the lower deck and quarter panel.
- Remove the tail lamp from the vehicle.
- Remove the socket and pull the bulb out if replacement is needed.
To install:
- Push a new bulb into place if required, then insert the socket into the lamp.
- Insert the wire harness through the hole in the lower deck panel.
- Install the wiring harness grommet into the lower deck panel.
- Place the tail lamp into position on the vehicle.
- Install the nuts to hold the lamp to the lower deck and quarter panel.
- Attach the wire from the lamp to the body harness.
- Place the trunk lining into position on the lower deck panel.
- Install the fasteners that hold the trunk lining to the lower rear deck panel.
- Check the operation of the lamp.
