Question about Dirt Devil M084600 Dynamite Bagless Upright Vacuum
Has a burnt rubber smell when i use it - Dirt Devil M084600 Dynamite Bagless Upright Vacuum
    Novelist:
  • 147 Answers
The belt may be worn or is about to break. It would be time to change the belt. This should solve the whole problem there. I believe the belt is a style 15 for this unit. your closest vacuum dealer should have one in stock.
Posted on Nov 05, 2010
Electrolux vacuum problems
could be a stratched belt that needs changing,smells like burnt rubber.Or the motor is overheating,check for any blocks in the hose or Power head.Hope this helps.Chris
Aug 11, 2014 | Electrolux Vacuums
Just replaced the roller on my oreck XL, and it is smelling like burnt rubber
If the roller bearings are starting to seize the the belt may be slipping
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Oct 25, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Smell of burnt rubber
Hi, the smell of burnt rubber is an indication of a broke or stretched power head belt. The belt can be accessed usually form the bottom. Chrs
Feb 21, 2011 | Bissell 6594 PowerForce Bagless Upright...
My dyson dc07 has started to smell a bit of burning.
This will be 1 of 2 problems.
1. If its a burnt rubber smell then its the belt that has gone and will need to be replaced.
2. If its a metalic smell then your motor is burnt out.
Replacing the belt is easy enough, the motor is a lot more complicated and should be left for an expert.
Feb 04, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Simplicity freedom vacuum has a burnt rubber smell
If the belt is continually wearing out I would think that the brush cylinder is not free to rotate. Take the belt off and ensure that the brush cylinder moves freely. If is does not, then you need to investigate why - probably something wound round it that has jammed it.
Apr 06, 2010 | Simplicity 7250 Deluxe Vacuum
Vacuum cleans properly,however smells like rubber. Nothing is caught in belt
You need to replace the vacuum belt. Even though the belt may look fine it is probably stretched or worn and slipping on the motor shaft and that is why there is a burnt rubber smell. You can get replacement belts here:
Replacement Vacuum Belts
Oct 31, 2009 | Vacuums
My hoover really smell bad, changing the bag and washing out the cylinder have not stopped it
Are you smelling a burnt rubber smell? If you are, you need to replace your belt. You can get hoover replacement belts here:
http://www.vacbelts.com/index.htm
Oct 24, 2009 | Hoover Vacuums
I've had the Hoover Windtunnel for a couple years now. Its starting to smell when you vacuum. Why and how do I fix it???
I was experiencing the same problem right after changing the belt for the first time, as my Hoover is just a few months old. I am assuming what you are smelling is burnt rubber, like your belt, right? Well, if you have changed your belt recently, make sure you are using the right one. If you're not using Hoover's authentic belts and you're buying it from Wal-Mart, make sure it's the correct one, otherwise it won't work right and/or it will give off a burnt rubber smell. One other thing you could try doing first, is raising the carpet height adjustment up a notch or two. If you have it too low and your beater-bar/brush roll has to work too hard, it will start to smell also.Good luck!
Aug 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Smells (burnt rubber) like it's overheating when I vacuum
I would check the brush roller and make sure it turns good and replace the belt on it . When you smell burning rubber most of the time it is the belt .
Feb 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Dirt Devil M084600 Dynamite Bagless Upright Vacuum Logo
191 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
