Question about Kodak EasyShare P880 Digital Camera
Turns off by itself
I have kodak p880, and now, I have noticed that it while taking pictures the screen goes black.When I press the button to take picture, it comes back.
It now frequently goes black while it is turn on.
  • 3 more comments
  • kodakgirl Jun 14, 2008
    I have change the battery and it still did not work. I have went to the kodak website and followed their advise to fix the problem myself and still did not work.
    How much does it cost to repair the body?
  • dlcooper Nov 19, 2008
    When the shuter button is pressed half way down to use auto focus the camera turns off, some time it turns back on some times you have to turn the on/off switch off and then back on
  • filmdiehard Jan 02, 2009
    Mine showed up when I took it to China. Unfortunately upon returning to Canada the problem could not be replicated and hence I did not try to get it repaired under warranty. I am also not confident that the camera will remain intact when the nearest repair depot is several thousand miles away. The biggest disappointment is Kodak's refusal to repair it at their cost on the ground that the problem was reported after the warranty period even though it occurred well before the warranty expired. Guess Kodak is now another manufacturer off my list when it is time to get a replacement camera.
  • Anonymous Jan 24, 2009
    Same problem. Except that now you can't turn it on anymore...
  • Tim Babcock
    Tim Babcock May 11, 2010
    Have you tried replacing the battery in it?
I have tried numerous avenues including email solutions from Kodak and possibility of reinstalling the firmware but none worked. I fully believe the problem lies in the power switch - it is no longer making proper contact when in the on position. The only way appeared to be to have it repaired by a camera repair depot preferably one that also happens to be authorized by Kodak. The repair cost estimate given to me was $70 Canadian. Unfortunately I reported the problem after the warranty period had expired and like most corporations today, Kodak absolutely refused to foot any of the bill once the warranty period is over. I have no good reasons to keep Kodak on my list when shopping for another camera. P880 was a great camera except for the unexpected switching off and Kodak has not made a replacement camera with the same degree of sophistication.
Posted on Jan 02, 2009
    It is probably the rotary switch that is dirty or corroded. The ultimate solution may be to replace the switch. A band aid solution would be to clean the switch. I am not sure how long this solution will be good for. First remove the battery. Use a fine screwdriver to move the part of the rubber moulding around the rotary switch out of the way to expose the part of the switch normally covered by the rubber moulding. Gently spray electrical contact cleaner around the exposed part of the rotary switch wiping away the excess. Turn the rotary switch back and forth a few times. Re install the flipped away part of the rubber moulding to its original location. Re install the battery. There should be no unexpected switching off for a while.
  • Chris greenwell Dec 07, 2011
    Many thanks for that fix, it worked like a charm, beats thumping the camera which was my previous fix!!
  • 3 Answers
I also have a P880 that has started shutting off on its own. Here's the fix that worked for me (well, not really a fix, but a workaround, and at least it points to the possible cause): as soon as the camera turns on, go into the menu and turn the autofocus off. As soon as I did this, the camera worked fine. I'm not happy about having to manually focus all the time, but I can at least get it to work, and if I end up taking it in for repair, this at least is a good starting point for the repair person.
Posted on Oct 16, 2009
I have the same problem for p880
Posted on Oct 13, 2008
I own an EasyShare 880 and it was turning off after turning it on. I too thought it was the on/off switch because it would stay on when the switch was rotated to the right, just not when I turned it the opposite direction to take photos. After reading postings on this site, I cleaned the battery and now it is working fine.
Posted on Mar 10, 2009
  • Kodak Master
  • 2,794 Answers
I've heard a lot of times it's cheaper to get a new camera but it wouldn't hurt to take it in and get an estimate on it.
Posted on Jun 14, 2008
My Kodak easyshare p880 will not turn on. It works when switching to favorites but I can not turn it on to take a picture or video.
Go to www.dpreview.com and Kodak Talk. Search the forum for "P880 Power Switch problem".
Problem can be solved with the use of WD40. Read the solution on Kodak Talk first!!!
Hope you'll succeed!
Gr. Mart
Jan 14, 2011 | Kodak EasyShare P880 Digital Camera
Kodak P880 camera won't autofocus. I bought a used P880 - seems like an awesome mid-high end camera for someone on a budget. Problem is that it won't autofocus properly. When viewing and pressing down on...
Hi mfkcolumbus,
Did you check the firmware version? If it's not v. 1.02, then get it at the Kodak support site and flash that firmware to your camera. If it is 1.02, then you may try to reflash that same firmware. Sometimes this helps strait'n out things.
Hope this helps.
Gr. Blackbear
Jun 27, 2010 | Kodak EasyShare P880 Digital Camera
No picture on monitor (monitor turns itself off)
You will need to take it for repairs.
Sorry
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Dell E773C 17" CRT Monitor
I can not see image on screen
If you can see the picture before you take it, then the taken picture is black - Camera needs repair at a service shop - aligment.
If you cannot see the picture before you try and take it - The lens shutter is jammed. A repair shop is required. Could be $80 -$200+ depending on parts costs and labour.
These are only probable answers.
Mar 21, 2010 | Kodak EasyShare C310 Digital Camera
Screen turns black when I try to zoom and takes a black picture
look ur CCD is BAD !!
just call Kodak i am sure they will doit Free becoz it is a manufac fault all manufacturers are doing it Freejust call them and ask them about BAD CCD !!
Pls rate me WELL !
Jul 03, 2009 | Kodak EasyShare V570 Digital Camera
Screen turns black after taking a picture
I also have a Kodak Easyshare and when mine did that I had dropped it and had to send back to factory for repair with no warranty on it if it had been dropped.
Jun 02, 2009 | Kodak Cameras
Kodak easyshare p880 camera
use WD40 or contactspray around the powerswitch after removing the battery.
then work the switch for a number of times
May 20, 2009 | Kodak EasyShare P880 Digital Camera
Black screen, not taking a picture
please check if the camera is in video mode. Just click on the button to switch from picture view and camera
May 16, 2009 | Kodak EasyShare LS443 Digital Camera
Camera goes off
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Oct 15, 2008 | Kodak EasyShare Z740 Digital Camera
The lens keep retracting everytime I turn on my camera...
Maybe the battery is low OR your press the button the turns the camera into the on you have to manual look through. The button should be at th e top left it looks like a screen, when pressed like 4 times the screen goes black. I'm not a expert but maybe this will help
Mar 01, 2008 | Kodak EasyShare C653 Digital Camera
Kodak EasyShare P880 Digital Camera Logo
702 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
