SanDisk Sansa Clip MP3 Player Logo
Susie Linnell Posted on Jun 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Menu changing modes
I can't seem to get my sansa clip to change from "music" to "fm radio" etc.
I push the menu button and then again and it just goes from song choice and back to the music icon???
  • bet103 Nov 07, 2008
    after I took it off the computer charged, it was stuck on music but couldn't scroll music, got it to change to fM but can't get back to music even with this suggestion. shouldI return it, I bought it last week.
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Jun 14, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2173435
Points
14133
Reset the player once to make sure it isn't a temporary glitch - reset will NOT erase all of your songs.
Press the downward part of the circular ring when the word "music" is on your screen, and see if it will scroll doen to FM; if the word "music" does not appear, press the left side of the circular ring until the word "Music" appears on the screen
Sansa clip user manual
You may download the Clip manual here.
You may download the Clip+ manual here.
6helpful
LANGUAGE IS NOT ENGLISH
It was your setting. You can change it to english.
For sansa clip:
1. From main menu, select settings (picture with 4 bars)
2. Use up/down button to find " FM...", the language option is right about FM..., select it and use up / down button to find English.
3. Press home button to come back main menu
Good luck
For sansa clip plus:
1. the same as about.
2. Getting into Settings, you have 4 options (Music, Audiobook, Radio, and System Settings). Languages with letters (a, b, c, ....), you can see "Radio...." option, move the selection bar down 1 - it is System Settings. If Languages without letters a, b, c, ...., you have to get in to each option, at each option you move the selection bar down or up to find letters " USB...." , it means you are inside System Settings, from USB, press down button 6 times, and select it (language option), scroll up/ down to select English.
3. The same
Good luck
2helpful
2answers
No sound from radio on sansa clip. mp3 playing still works fine.
Did you accidently pause radio. put sansa in radio mode and push the play/pause button.
1helpful
I have a sansa clip and I can;t get it out of the radio mode and back to playing my music/books. I have tried holding the power button for 20 seconds multiple times
Do you know how to get to in main menu? using menu button - the small button under screen, on the right. After you press that button, you can see "FM Radio" with a picture, use up/down button to get into Music options.
Good luck
6helpful
Sansa clip 2mg fm radio not putting out sound
Go into the Settings menu of the Sansa, and change the region to "World" if you live outside the US, and change to "United States" if you live inside the US. Then, go back to the Radio mode and see if there is an icon that looks like a block (technically, a "Stop" sign) - if there is, press up on the clickwheel - it will get your radio off of pause mode. You radio should now work again.
Can't see screen or change modes on sansa clip 2gb mp3
You posted your question under "Sansa Clip," so this is a Sansa Clip manual:
http://www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
This model goes to "sleep" quickly by default - pressing any button will wake it up. The button that looks like a house (if the paint didn't get rubbed off already) allows you to go one level higher in the menu tree. Have fun with it.
-Tha Mp3 Doctor
Bought Sansa 2GB mp3 player and can't work radio
Dude I have one in front of me so listen and follow along first turn the unit on, second push the menu button, this is the very small buttonright to the right of the SANSA namewhen you push that button the first thing you will see is the words MUSIC while thats on the screen hit the play button that looks like this >|| and you will scroll through all the settings you will see the fm radio selection when you get to it hit the middle button and the radio will come on.
1helpful
The sansa clip mp3 player has totally frozen up-stuck on fm radio
Press the Home button and see if it will go to the settings menu. If it will, change the USB Mode to Auto. If it won't, hold in the power on/off button for 15 seconds to reset the player, and try again.
-Tha Mp3 Doctor
1helpful
Sansa Clip Stuck in FM mode - Won't go into music menu
Press the little button that looks like a house to go back to main menu
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
