Question about Whirlpool Duet GHW9150P Front Load Washer
Change someone didnt take the change out of their pockets..now i have a coin in one of the fins in the washer..how do i get it out?
  • 246 Answers
The fins slide towards the back to remove them. However there are tabs on both sides you have to use a small flat head screw driver to pry and can easily break.
Posted on Jun 15, 2008
We have a dryer fin with something rattling around in it. Do the fins come off?
Need a model number for the dryer for a more definitive answer--usually you would have to open the top cover to expose the drum. Depending on the model dryer, some baffles(proper name) are screwed onto the drum, some have plastic tabs which must be carefully pushed in order to remove the baffle. Most likely, the rattling is caused by coins left in pockets--they won't damage the dryer but can be irritating to listen to. Front load washers are notorious for trapping coins in the baffles of the rotating baskets--and that is A VERY EXPENSIVE REPAIR if you want to have the coins or objects removed.
Aug 14, 2015 | Dryers
Tip
Washer Repair Boise - Whirlpool Cabrio Pump
I've replace many pumps on the whirlpool Cabrio and most of these washer pump failures could have been prevented by removing coins from pockets. Many times coins will make there way to the outer tub and get sucked right into the pump to create a rattling sound. That rattling sound you hear is the impeller spinning against the coin. Since the impeller is plastic, it doesn't take long for the impeller to wear down. Just a tip, please remove coins from pockets. You'll save money and time :->.
A tip from Western Appliance Repair
Washer Repair Boise
on Oct 12, 2010 | Washing Machines
Coins end up in the drain pump and take out the impeller fins. I replaced the pump but heard more coins in the pump. Took the pump out removed the coins and reinstalled the pump and works great. How do i...
try and check your clothes before putting them into the machine. and ensure all pockets are clear of debri before starting the wash, i dont think there is a screen device or filter hose that you could get to help so my first suggestion is the best one i have, best regards
Oct 30, 2013 | Samsung WF337AA Front Load Washer
Will not drain and stops but does not give an error code.
Check any pump filter and outlet hose for blockages, if all is ok check pump.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Mar 06, 2011 | Maytag Neptune Washer
Coins get caught in dryer fins. Just recently paid $80 for the service call to remove coin. Seems to be a design flaw or recurring problem. What do I have to do, what kinds of tools do I have to have to...
Good day,
Foreign objects such as pins, needles, nails ect. can cause even more damage or disruption than coins.
Standard practice is to check all pockets before clothing is placed in laundry equipment. No manufacturer designs their equipment to handle items such as these and would not cover issues caused by them.
Oct 17, 2010 | Maytag Dryers
Washer doesn't drain just buzzes
Most likely you have a coin stuck in the drain pump. Mine did the same thing, and we removed the drain pump, then removed the coin and it began working again. Just be sure to check all pockets for coins as this is a big problem with the Cabrio washers.
Oct 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Hole in pump caused by coin -- causing flooding
There is no screen! I bet it was a dime that was caught in the pump. It has happened to me several times to the point where we double check all pockets when loading washer. Coins larger than a dime stay in drum or in lower basket. Poor design! I now leave the back of washer loosened and have mastered pulling hose off the PLASTIC pump housing and reaching in to pull out the coin.
Apr 06, 2009 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore elite drum baffle dryer
remove the top panel and each fin has 2 5/16 screws holding them to the drum. turn the drum so the fin is on top and remove the screws then remove the coins
Oct 18, 2008 | Kenmore 88752 Top Load Stacked Washer /...
ASKO w6011 FRONT LOADER
Try to Open the safety compartment using a screwdriver under the wash machine in the front.
Then open the big white knodb this will cause the wate to drain out which is fine.
Then clean this out. Usually you will find coins and stuff here from years of operations from pockets. clear these out and your problem maybe fixed. worked for us
Jun 09, 2008 | Asko W6021 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
