Question about HP Compaq Presario V2000 Notebook
Battery not charging...but is recognized by V2000
My fiance's Compaq V2000 is sick. About 3 months ago, I switched to a new battery. It charged/discharged just fine. Than two days ago, the laptop would not power on unless plugged into the AC unit. The battery status in the system tray states that it is charging with a level of 55%.
The battery charge light on the front of the laptop is lit, so I image it is getting power. I took the battery to a friend's house and it worked on his similar laptop so I am pretty confident it is not the battery (unless this was a fluke).
Am I correct in thinking its the charging component on the MoBo?
  • microcheck Mar 07, 2009
    Same problem, Got new battery with some charge in it already but V2000 sees the batery but won't charge it. If I take out the battery with PC running it says charging but still does not. Could it be the charger. What Amps are required by this unit? Does anyone know, it's not written on the bottom of the laptop like most are!
Compaq v2000 not charging and no power on if any solution plz......sir
Posted on Mar 28, 2011
    President:
  • HP Master
  • 1,314 Answers
My guess since the battery checked fine in another laptop would indeed be the charging board or charging circuit on the motherboard.
Posted on Jun 14, 2008
I have an compaq presariov2000 laptop. the problem is battery not charging and the charging symbol is also in a hide and seek mood. I also try scan for hardware changes method but it won't work. plz help.
go to compaq's website, download the latest Bios Update, run the bios update while the power suply is connected on the laptop. after the update, the power adapter should be recognized by the laptop
Sep 07, 2010 | HP Compaq Presario V2000 Notebook
Battery problem with HP Compaq Presario V2000 laptop
When batteries fail, they usually lose the cells inside them, which means that the cell is no longer able to function as a holding cell for power and therefore cannot do its job anymore, when a battery fails to hold and refuses charging it is bad and needs to be recycled. The flashing is telling you to purchase a new battery. The larger the number of cells in the battery, the longer and better it will perfrom,,RE: 6 cell, 9 cell, 12 cell.
Jan 13, 2010 | HP Compaq Presario V2000 Notebook
Compaq Presario v2000 notebook reduced battery life
you may try:
1) check the battery alarm at windows power managment, to set 5-10% alarm level.
2) discharge the battery to the empty then charge longer time, you need monitoring how long it charged (see charge lights change), need to change new one if charging time much less then before(less then 10-20 minutes)..
3) plug-in AC adapter monitoring charging current,
this step you need a current meter to make a series connection in the circuite, the battery is over life cycle if the current less then 500mA.
May 02, 2009 | Computers & Internet
Presario V2000 battery not recognized
you may need to have that battery charge for a while, until it can be seen at charge level..or simply check the connections to see that there is no junk in the connector..
Nov 21, 2008 | HP Compaq Presario V2000 Notebook
Presario V2000 - Does not turn on..
Hi
Have you tested your Power Adopter, it is working if yes check the battery, This may be the problem
Boopathy
Aug 10, 2008 | HP Compaq Presario V2000 Notebook
Compaq v2000
you would have to pull down the laptop if you can. there seem to be something shorting out the 14.v battery connection allowing it to discharge the charge from the battery when off. if you can get the motherboard exchanged for a new one thats you first go, because the problem is def the motherboard.
Jul 02, 2008 | HP Compaq Presario V2000 Notebook
Modem driver
Hi Mofya,
HINT: your presario may not really be a V2000. My fiance's V2000 is actually a V2402AU. Try searching for the drivers for that model instead.
Jun 07, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 touchpad/battery charging problems
I noticed you were talking about over heating issues. Does the mouse issue happen when the computer is on for a period time?
I know with some laptops there is software for the "gadgets" on the mouse pad. If you have software related to it.. try reinstalling.
I am getting mixed thoughts of what you maybe talking about... please explain.
Nov 13, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
255 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
