I have a LG dryer Model # DLG5932W It's a gas dryer.It runs fine but does not heat.Not sure on what I can check because I have no access to a repair manual.Looking for some help on how I can check a few things to narrow down what it might be.Also Have a Washer LG WM2032HW it's a matched set,The board has been replaced because of getting an error code saying the drain is clogged.But it is not.It will wash the load and when it gets to the last raise and spin cycle it shuts down gives an error code.Any help would be great.
    President:
  • 2,468 Answers
You can first check the ignitor/glo coil and high-limit thermostat on the burner tube for continuity,then the thermal fuse,cycling switch for continuity on the blower housing,and possibly the gas valve coils on the gas valve,unfortunately if its the gas valve coils you need to replace the whole gas valve because you can't buy just these 2 coils that mount on the valve,also the control board is a possibility,if you also need some PDF exploded views and diagnosing charts theres a web site to go to it is; appliancejunk.com, scroll down to L.G. and open it and go to dryers and download your model#...........good luck
Posted on Nov 21, 2010
I have an LG dryer model DLG8388WM and it doesn't heat up. From looking at this website it seams to be the coil attached to the gas valve. Is this easy to install?
This is a very common problem amongst gas dryers and although some dryers vary, the coils (usually 2) are easily accessible near the front of the machine behind the bottom panel. They are inexspensive and certainly worth trying prior to calling out a repairman. Be sure to unplug the machine when installing the coils. They are generally held down by 1 bracket on the top by 1 or 2 screws and have a plug on each.
Aug 06, 2011 | LG DLG5932W Gas Dryer
LG dryer not heating, checked thermostat assembly and their fine,any other options?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 10, 2010 | LG DLG5932W Gas Dryer
Just installedmy ga dryer, it does not heats up
Check to make sure the gas is turned on. If it is, you will need a qualified LG tech to diagnose the problem.
Good luck
Sep 26, 2010 | LG DLG5932W Gas Dryer
GAS LG DRYER TUMBLES BUT DOES NOT HEAT, WHAT COULD BE WRONG? CHECKED THE BREAKER AND GAS LINE, BOTH ARE ON AND GOOD.
Pilot light (flame) may have gone out..Dont know if you are on gas bottle or mains,if on bottle make sure not empty..most likely Pilot Light (flame).cheers
May 28, 2010 | LG DLG5932W Gas Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
DLG5932W, not drying completely. I hear gas burner come on but only stays on for short time. Same condition in manual mode
If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | LG DLG5932W Gas Dryer
Not heating
Hi, If you have a gas dryer2_bing.gif.
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
May 09, 2010 | LG DLG5932W Gas Dryer
Dryer runs but there is no heat. Clothes spin but aren't drying. Any help is much appreciated!
On a gas dryer that will not heat, the first thing to check is the ignitor. The ignitor should heat up and glow orange if it is working. If not, the ignitor is defective. The next thing to check are the gas valve coils. These are electrical solenoids that are located just above the gas valves. When energized, they open the gas valves and allow the gas to flow to the burner and be ignited. If everything looks like it is operating well, but the dryer is still not heating/drying properly, the next thing that I would consider would be a faulty high limit thermostat. Sure hope this helped and best wishes.
Jun 01, 2009 | LG DLG5932W Gas Dryer
Gas dryer no heat
defective gas vavle..replace
Feb 09, 2009 | LG DLG5932W Gas Dryer
Runs but no heat
I WOULD LIKE TO KNOW WHERE THE RESET BOTTOM ON A (LG-GAS 7.0 DRYER)
Jul 30, 2008 | LG DLG5932W Gas Dryer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
