Question about Coleman Powermate Proforce 2500 Generator
GENERATOR WON'T START. IT HAS NOT BEEN STARTED IN ABOUT THREE YEARS.IT DID START AFTER I REPLACED SPARK PLUG,BUT ONLY FOR ABOUT 30 SECONDS..ALSO SPRAYED STARTING FUID IN CARBERATOR. NO GO.
    Sergeant:
  • 415 Answers
FIND THE FUEL SHUT OFF VALVE.IF IT WAS CLOSED WHEN YOU HAD IT RUNNING,THE FIX IS AS SIMPLE AS DRAIN OLD FUEL,REPLACE WITH FRESH GASOLINE,OPEN THE VALVE TRY TO CRANK IT AGAIN.
IF IT WAS OPEN WHEN IT WAS RUNNING,SOUR GASOLINE AND VARNISH HAS LIKLEY GOT TO THE CARBORATOR.
REMOVE THE AIR FILTER,LOCATE THE BOLT IN THE CENTER,ON THE BOTTOM OF THE CARBORATOR BOWL AND REMOVE IT. CAREFULLY EASE THE BOWL STRAIT DOWN,AS NOT TO BEND THE TAB THAT CONTROLS THE FLOAT LEVEL,OR LOSE THE FUEL INLET JET. EXAMIN THE BOWL FOR CORROSION OR GUNK.
THIS IS AN INDICATION THE CARBORATOR MAY BE PLUGED WITH GUNK,WHICH COMES FROM GASOLINE SOURING AND TURNING TO VARNISH AS IT EVAPORATES OVER TIME.
ON THE CARBORATOR,WHERE THE BOWL WAS TAKEN OFF,IN THE CENTER ON THE BOTTOM NOTICE THE FUEL PICK UP TUBE,TAKE A PIPE CLEANER AND CLEAN IT BY PUSHING STRAIT UP AND DOWN A FEW TIMES,THEN FLUSH IT WITH CARB CLEANER.
REPEAT THIS UNTIL IT IS CLEAR.
LOOK CLOSELY AT THE SIDE OF THE PICK UP TUBE FOR A VERY SMALL HOLE,WITH A SMALL WIRE,CLEAR THE HOLE AND FLUSH WITH CARB CLEANER.
CAREFULLY REPLACE THE BOWL AS NOT TO BEND THE TAB ON THE FLOAT,MAKE SURE THE NEEDLE JET IS IN THE NEEDLE SEAT AS YOU PUSH THE BOWL INTO PLACE.
PUT THE BOWL BOLT BACK IN,CAREFUL NOT TO OVER TIGHTEN IT.
WITH FRESH GASOLINE IN THE TANK,AND THE FUEL VALVE OPEN,YOU ARE READY TO TRY CRANKING IT.
IT MAY TAKE A FEW TRYS.
IF YOU FEEL CLEANING THE FUEL SYSTEM IS TOO MUCH FOR YOU,PLEASE DO NOT ATTEMPT THIS.TAKE THE MACHINE TO A SMALL ENGINE MECHANIC.
YOU MAY CAUSE COSTLY DAMAGE TO DELICATE PARTS OR UNINTENTIONALLY CHANGE THE FLOAT LEVEL CAUSING FLOODING OR STARVING OF FUEL TO THE ENGINE.
BEST OF LUCK...
Posted on Nov 07, 2010
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Jan 21, 2016 | Electrical Supplies
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
Husky generator won't start
did you try cleaning the conductor that goes to the spark plug if not try to clean it with a real fine sand paper it should do the job.
Oct 27, 2012 | Husky Portable generator
Snapper mower 331416kue won't start
You can try buy a new spark plug and replace it with the old one.
I had the same problem!
You just have to keep pulling until it catches!
Or maybe it's the carburetor that needs to be replaced!
I had the same problem wih my scooter.
I just changed the carburetor and it worked fine :)
Sep 08, 2012 | Garden
Zafira 1.8 petrol 03 runs rough for 30/50 seconds when started then ok but a little sluggish
The "won't rev" part sounds like a preventative so you won't destroy the engine from cold start-up. The sluggish part sounds like bad fuel or spark plugs. Where do you buy your fuel and what octane is it? and have you Changed your plugs?
Jun 25, 2012 | Cars & Trucks
Troy bilt 5550 generator no start please help
fuel, fire, mechanical. Miss one and she won;t run. Are you sure the gas was good? Not some old can laying around that may have turned or become water contaminated? If it was fresh gas, then take off the air cleaner and spray a little wd-40, or ether, or brake cleaner whatever is flammable into the carb throat. Just a 1 second shot is all it should need. Try and start with that. If it starts and then dies quickly, still a fuel problem. maybe a gasket is damaged, or the jet is clogged. When you said you checked for fire, you acutally took the plug out and had it grounded while spinning the motor and saw spark? If you saw a hot spark then you have eliminated fire. Mechanical not likely if it was running well a short time before. If a valve was damaged, it would still run but not too well. My gut feeling is it is related to fuel.
May 25, 2010 | Briggs & Stratton Power Products 5,550...
Coleman Powermate Proforce 2500 Generator Logo
582 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Sheldon Dedek
Craig Butler
Craig Butler
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
