Question about Canon MX300 Office All-In-One Printer
The in use/memory light is permently on in mt canonMX300. Unpluggin and repluging in does not do anything. Can not make copies or anything.
  • rkoor Nov 05, 2010
    Good morning.
    I After step four the screen is blank and the alarm lites up.When i push the stop/reset button and hold for about 10 sec nothing happens.
    What did i do wrong?
  • rkoor Nov 06, 2010
    in step four when i release the power button the alarm light goes on and then nothing works. i can not turn off with the power botton? Holding the stop reset button does not turn off the alarm light. Any ideas
    Guru:
  • 731 Answers
  1. Turn Off the printer.
  2. Unplug the power cable and USB cable from back of the printer.
  3. Removed the power cable from wall outlet.
  4. Press and hold the power ON button for 60 seconds (Power Drain).
  5. Connect the cables and turn ON.
Posted on Nov 06, 2010
    President:
  • 2,923 Answers
This problem can only be fixed by replacing the logic board.Is it under warranty? If yes, I suggest to send it back to the manufacturer for repair.
Thank you and good luck!
    President:
  • 4,070 Answers
Hi! Please try this procedure.
- switch off the unit and disconnect the power cable
- press and hold the power button then plug the cable to power source
- while pressing the power button please press the cancel/stop red button
- release the power button then it will turn into factory mode
- wait for 10secs till it says idle
- press > once *shipping mode 3* then press ok.
- press ok again *without cleaning*
- a test page will print
This will reset the printer's system and you'll be good. Hope this helps and thank you for using FixYa!
Posted on Nov 05, 2010
  • dj_relly999
    dj_relly999 Nov 05, 2010
    Hi! HOws it going?
Camera does not come on
Make sure to remove the battery first ... make sur your camera has a full battery charge ... then select "MENU" scroll through options until you find "FORMAT". This will re-set all your settings back to factory settings ... you will lose any saved pictures on the internal memory only. ALSO when your camera light goes on try to hit the PREVIEW OR EDIT SElection. I* cant see how the memory card being removed would cause your display to permently be damaged. You can also try to connect your USB/AV port. Use your A/V cable with the two input connections to a TV to see if it is putting out an image. Hope all goes well
Sep 27, 2007 | BenQ DC C500 Digital Camera
My rear tail light bulb is on permently even with the lights off. their is power going to it all the time. ive replaced the plastic bulb housing and the plug that fixes into it and still the same . could...
PROBABLY IS THE SAM UNIT. HAS ANYBODY BEFORE WORK EITHER FITTING ANYTHING LIKE RADIO? IF SO CHECK IF BY MISTAKE USED THE POWER WIRE FOR SOMETHING ELSE . IT HAPPENED TO MY CUSTOMER RADIO FITTING USED THE POWER WIRE OF LIGHTS TO RADIO.
Aug 30, 2012 | Cars & Trucks
How do I transfer photos to my new dell computer using the cord. I do not want to take them off my memory card too
Hi! create an IP AD to have access with other computer if u're done, if you see your new dell in just copy and paste it in to..
May 31, 2011 | Dell OptiPlex 380 MT Desktop Computer...
Bought a canonmx300 printer scanner and fax all-in-one. I lost software but it picked it up on the internet for the printer and fax but it wont seem to scan other than to copy can someone help to resolve...
If you follow the link below, you should choose your operating system, and then download the MP Navigator.
Installing that should allow you to scan with youir MX300
Thanks - Sam
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#DriversAndSoftware
Sep 07, 2010 | Canon MX300 Office All-In-One Printer
I have nokia5130 xpress music and sandisk 2 gb micro sd card.but now every time i connect to computer the phone display "card is operating by another program.please wait".even it does not open through by...
your card may infected by viruses so scane for viruses if the problem still ocurs then copy all the data and then format the card then recopy the data to the card then try, gud luck.
Jan 14, 2010 | SanDisk 2GB microSD Memory Card
Power indicator blinks red
According to the shop manual (found at http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00261093/c00261093.pdf), this indicates no memory. You should open the case, remove and reinstall the memory modules. You might want to use some compressed air to blow out the sockets prior to reinserting the memory modules). If this doesn't work, you'll need to replace the memory.
Dec 19, 2009 | HP (REFURB) HP DC5000 XPP C 2.8GHZ 40GB...
"Battery missing"on screen,but Unit is new out of box.
Before you do anything with your Garmin you should register it on line ay the link below. If you don't nothing will work correctly. Garmin installs a key when you register your product and you also get personal one on one service. Please rate me if this was helpful, Thanks, Sea Breeze
https://my.garmin.com/mygarmin/mapDownloads/mapDownloads.faces
Aug 05, 2009 | Garmin GPSMAP 276C GPS Receiver
How do you get a fax from memory
May 19, 2009 | Canon FAXPHONE L80 Laser
Wii won't work after "incorrect memory card" was inserted.
you shouldnt need a memory card to save wii games it has 512mb internal memory.unless your trying to play gamecube games on it.the wiis security features are incredible if it cannot recognize a controller or memory card it will power down.make sure you are using a SD memory card because it will not accept anything else.it will power down for safty reasons.
Jul 14, 2007 | Nintendo Wii Console
Canon MX300 Office All-In-One Printer Logo
59 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
