I connect my Technika TT-03 to my acoustic solution DV600B digital freeview reciever and when i search for channels none of them show up
  • 476 Answers
SOURCE: Philips DTR220/05 digital freeview reciever not recieving anymore
If the box is still receiving some channels, then the box is probably not at fault.
If you have done the full "First time Installation" rather than search for new channels, then eithe the aerial, connection or signal is likely to be to blame.
There have been several changes with the Freeview service over the last few months, and there will be more in the run up to analogue switch off.
In some cases, channels have moved, and in other cases the service has been switched off for a short period, low power etc.
Check the aerial on a standard analogue signal, if the quality is poor, then this rules out the box.
Posted on Feb 23, 2008
SOURCE: Nikkai A75HQ Digital Freeview Receiver
I'm using an attenuator 3db/5-1000Mhz - I get all channels. Without I got 100% strength,0% quality. hope it helps
Posted on Jan 11, 2009
DirtyDozenUK
  • 57 Answers
SOURCE: Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Posted on Feb 05, 2009
SOURCE: Samsung and Technika compatability
I am sorry I thought that this was a free site
Posted on Sep 20, 2009
SOURCE: Cannot re-tune digital freeview channels. Search
Searched Sony webste. Need software update to be loaded by an engineer, or buy a freeview box.
Posted on Oct 10, 2009
I was given a technika hd ready dvbt dvd built in freeview with no instructions.I need instructions how to tune in freeview.It had previously had the freeview tuned in but now the channels are not...
hi,
First of you have to check the Atenna connection in the rare of your tv. Check for any loose contact on the connection of the wire to the pin. may be its the cause for showing signal as 0%. you can confirm the same by connecting the tv at the place where you doughters tv is connected. If there you get the picture then there is some thing wrong with the atenna connection.
If want information how to tune your tv then need information like BRAND and MODEL NUMBER of you TV.
ok
Aug 05, 2011 | Televison & Video
What does "freeview database empty"
My tv has been working fine and all of a sudden it wont find any channels on channel search and says "database empty" can anyone help??
Mar 08, 2011 | Televison & Video
I Have a 15inch acoustic solution telly with built in freeview model number astv15id , however it has lost most of the freeview channels how do i retrieve them back.
Go into main menu set up and navigate to option to rescan. (might be called install or re-install stations)
Note - if it has lost channels it may be due to poor signal quality - check the quality of your aerial connections. You may also have lost channels if your area has recently been subject to 'digital switch-over' . Although they are already on digital tv all Freeview boxes will need re-tuning after switch over because this entails a change of some channel frequencies post analogue.
Feb 26, 2011 | Music
Hi my mum has been given a dvd/video combi Technika DVR100 as her one does not record her progs while she is at work after the digital changeover.. question is will this record her progs which she watches...
You would have to connect the free view box to the vcr with a scart lead.Plug it into av2 on the vcr.To record select av2 on the vcr then set the channel on the freeview box.
Oct 16, 2010 | Televison & Video
Ive just been given a Technika television LCD19DVDID 308 and I can't find out how to watch analogue channels,can anyone help me please?
have fitted a new aerial as tv was connected to sky and now cant get any freeview channels keeps saying no signal what am i doing wrong
Mar 16, 2009 | Sampo PME-50X7 50 in. HD-Ready Plasma...
Went from bt digital tv back to technika built in freeview, now freeview doesn't work. Only have 4 channels?
go into source and change it onto dtv and do a fti on the unit otherwise to get back to bt digital go into source and change to scart/av/ext if no effect try a new scart lead, if is connected via hd, go into source and change to hdmi this should change it,
Mar 01, 2009 | Sampo PME-50X7 50 in. HD-Ready Plasma...
Cannot find freeview/digital on our new TV
You can only get the freeview / digital channels through cable by subscribing to a package which includes them. They will then supply the necessary decoder to get the channels. Otherwise you will need a digital aerial and a freeview box if you tv is not dtv ready.
Jan 03, 2009 | Televison & Video
Technika 15.4'' tv/dvd can't find antenna that is plugged in
When almost all TV stations went digital, analog TV signals received via an antenna all but disappeared in the United States. So you will not be able to get much, if anything at all without a digital TV connected to a cable system or a satellite system. Welcome to the new economy! You want it? You will PAY for it! Radio (first FM, then AM) will most likely be the next casualty of the new economy!
Apr 19, 2017 | Televison & Video
Fault
as long as you have a good digital aerial connected to the recorder and you are in a good signal area then the channels should have been found automaticaly and stored on the machine.. a manual search and store would also work ok.. check your aerial connection/aerial type and any info you can find on freeview availabiliy in your area.. do you or anyone in your area have any other freeview device running ok?
Jul 28, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Feb 23, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
