Question about Locks & Locksmithing
I have a Safewell Electronic Safe which I cannot open as the batteries have run down. The instructions say use the emergency override key which I have tried to do but cannot get it to work. It does not seem to go far enough into the hole to turn the mechanism. Any suggestions apart from calling in a locksmith?
  • peter251 Nov 05, 2010
    Tried the WD 40 and tapping with a hammer but shows no inclination at all to go into the lock. The key just keep falling out again.
  • peter251 Nov 08, 2010
    Justaskjoe suggested spraying WD40 in the lock but this has made no difference. Someone else sent me the manual for a Cannon safe but this is not the same as my Safewell model.
    I have a cylindrical override key but the lock barrel does not seem to be lined up with the opening so the key will not go in. I cannot see any way to correct this. If anyone has experience of this problem I would be glad to hear from them.
    Peter
  • 10,319 Answers
Someone jambed something into the keyway blocking the entrance for your key. You can do as a locksmith would by using a hacksaw blade which is grounded down ever so thin with the teeth showing and a little bit of the blade left as well. This way the obstruction can be racked out of the keyway
Posted on Nov 10, 2010
  • 10,865 Answers
Hello Peter. Get some penetrating lubricating spray such as WD-40. Spray it into the key hole and onto the key. Insert the key and tap it lightly with a hammer. Turn it. If it still isnt in far enough let the penetrating lube work over night and try again. Reapply the WD-40 as needed. Joe
Posted on Nov 05, 2010
My Safemark Systems electronic safe won't open. I have the code but my batteries are completely drained. How do I get in safe?
4 0 Electronic Safe
use your cobra key or buy this Emergency Handheld Override,that goes to it,or replace the batteries.
Emergency Handheld Override EHO
Safemark Systems
2101 Park Center Drive
Suite 125
Orlando, Florida 32835
USA
1-800-255-8818 USA
1-407-299-0044 International
1-407-299-7650 Fax
1-800-299-4288 Tech Support
May 01, 2015 | Locks & Locksmithing
Safewell EX2005327788
A set of emergency keys is supplied with every Safewell safe. In case the batteries drain out, you may use the emergency key to open the safe. These keys override the digital password. Remember, never keep the emergency keys inside the safe.
Jan 14, 2015 | Home Security
I AM USING GODREJ E SWIPE ELECTRONIC SAFE, SINCE LAST DAY IT WAS FUNCTIONING PROPERLY. BUT TODAY WHEN I TRIED TO OPEN IT AND JUST INSERTED PASSWORD ITS NOT OPENING. POINT TO BE NOTED THAT THE PASSWORD IS...
Is the battery dead?
Has someone tried to get into the safe causing the keypad to "freeze"?
Have you tried the "Emergency Manual Override" also know as the key? I hope the Emergency Manual Override Activation Device (the key) is not stored inside the safe.
Dec 05, 2014 | Computers & Internet
Safewell safe EX2007316659 batteries dying and can't open
I have had zero success in finding out any information about various models of electronic safes--no manufacturers' website, no online manuals, etc. Many of these safes are imported from overseas manufacturers.
Dead or dying batteries is a common problem, and I gather that many models of safes come with an override key.
It is incredible how many people have found the best place to keep their override keys and/or instruction manuals is INSIDE their safe!
I ask that anyone with owner's manuals or instruction sheets please publish them on this website for the benefit of others, but that is unlikely as they aren't the ones seeking information--they already have it!
Sorry I can't be of more help!
Nov 10, 2011 | Locks & Locksmithing
I hv a safewell safe. i locked the emergency key before setting my personal key inside the safe. how to open the safe now?
You'll most likely need help from a locksmith. Basically, the lock can be picked, to get the safe open. There might also be a factory pre-set code.
Aug 16, 2011 | Locks & Locksmithing
I have a safewell electronic system EX2005156761 without keys and the batteries run out. How can I open it?
Without having to drill it out, it is possible for a locksmith to impression a key for the safe. Another possibility is contact the manufacturer, give them the model and serial number AND show proof of ownership. They MAY be able to send you a replacement key.
Jan 26, 2011 | Safe International Digital Electronic Safe...
I have lost our spare key - where can I buy a
HUBBIE LET SAFE BTTERIES RUN OUT THE LOST BOTH KEYS ( BOTH ON ONE KEY RING??? )
NEED KEYS FOR A ..
NUTOOL SF10 ELECTRONIC DIGITAL SAFE..
HELP NEED PASSPORTS!!!!!!
JOAN
Jan 31, 2010 | Safe International Digital Electronic Safe...
I forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Good luck
Sep 14, 2009 | Locks & Locksmithing
I have a safewell electronic safe and no keys and lost code ex2007127402 can i have a code to over ride and open it
hi : about the stockwell safe ex200----- 2535-EA
if the safe still has charged batteries you can deactivate any sceurity code by access through a small hole on the rear of the safe, if you can get to the rear area of the safe.. You need a long screwdriver to reach to the inside of the front of the door . Their is a reset button on the inside of the door in the lower right corner area( "B" button) on the end - not on the flat face surface of the door but on the vertical face( hing plate). You'll have to feel around and push the screwdriver sideways to push the button in.it will beep . YAHOO- YUH DID IT !!!. Then you can reset your own code.if you need further instructions call me . icq. 33819110 or echarron1@cogeco.ca
Jul 26, 2009 | Locks & Locksmithing
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Locks & Locksmithing Logo
386 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
