Question about Dell Dimension 4600 PC Desktop
No anything I have a Dell Dimension 9100. Last night while trying to plug in a USB cord for the widescreen monitor, I got a USB power overload error which I reset after trying to plug it in twice. This is a weird Usb cord because it has four small holes that plug into four pin like projections in the Usb port. Upon examining the port, it looks like the pins might not be lined up quite right. I suspect the cord was pulled out when we moved the computer earlier to install a new hard drive. Anyway, on the third try to plug in the Usb cord we got the blue error screen and were unable to do anything but turn off the power. Now the computer will not power up. All we get is two amber flashes when we push the power on button. I've tried reseating the power cord, reseated the power and 20 pin connection on the mother board and on all the internal drives. HELP!!!!!
  • 3,940 Answers
Flashing amber power button indicates a failure of the power supply.
Posted on Jun 14, 2008
  • IQUIT Jun 14, 2008
    I am pretty confident that replacing the tower power supply will get the system running. The issue, that started the problem may be more involved. You describe what appears to be a damaged USB port on the motherboard. If the pin connections are bent abd you push the plug in the port you may ground out the power lead causing a short circuit. The MAY have blown the power supply, but also MAY have damaged the motherboard.
    I suggested the power supply 1st as it is the most often failing part and cheaper than the motherboard.
Dell video card
try with vga.still the same use your warranty.proberly brooken
Apr 07, 2013 | Dell Computers & Internet
Dimension 9100 PC Desktop: no sound dell dimension 9100...
Make sure physical cables are plugged in correctly from speaker to audio ports. Check audio driver if installed, if not you can download the driver from the dell website:support.dell.com.If driver is propely installed check sound/volume settings, make sure nothing is set to mute...Hope this helps...Cheers!!!
May 17, 2010 | Dell Dimension 9100 PC Desktop
My dell inspiron 9100 will no longer charge. it was working fine last week. i unplug it and it discharges like normal but when i plug in the cord it says its charging but will not go above the percentage...
Depending on how old the laptop is, the battery may need to be replaced. Since it charges, I would not suspect the power cord, so indications may lead you to requiring a new battery.
Good luck
-Carlos:
Dec 16, 2009 | Dell Inspiron 9100 Notebook
I have a dimension 9100 that will not boot. I get
try a new cable for the hard drive and disk drive and see if no result try diferent hard drive please thanks
Oct 22, 2009 | Dell Dimension 9100 PC Desktop
Monitor no power
manipulate each ac power cord wiggle it . PS died?
Aug 01, 2009 | LG 19" Widescreen Flat Panel LCD Monitor
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
Nov 11, 2008 | Dell Dimension 9100 PC Desktop
Dell Dimension 9100 PC Desktop problem
I'm not sure where the floppy drive comes in, but if you have usb connectors on your mobo then you can connect the 5 pin connector to half of the usb pins.  Try that and see what happens.
Oct 25, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 4600 PC Desktop Logo
93 people viewed this question
Alun Cox
