Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Replaced the Lamp and get nothing, SOund works, no picture
Error code that came back was 34. Please advise.
  • losttech1 Jun 14, 2008
    If you wouldn't mind posting the link, that would be great. Whast the skill level associated with this repair?
  • lisadu603 May 11, 2010
    Can you provide details as to what board to replace the 2 3300uf caps?
    An image with arrows would be very nice.   Thanks in advance.
  • Mitsubishi Master
  • 8,617 Answers
Replace both 3300uf capacitors on the PWB thats a common cause with that model when it displays a 34 code which is lamp abnormality. if you need more information and I can psot a link where you can get the kit to repair your set with full instructions.
Posted on Jun 14, 2008
  • Sonny Berry
    Sonny Berry Jun 14, 2008
    Heres the link, they dont list all the kits they have, but leave them a email indicating your model number and what your problem is and they will respond quickly. The skill level is basic soldering ability.Heres the link.
Samsung DLP TV no picture or sound 2 weeks old lamp
Hello, DAvid43, what model is your Samsung DLP tv?
Jun 01, 2008 | Televison & Video
WD-73733 Sound no picture, replaced lamp, still not working
I assume you were getting a code flashing on the front indicator showing a lamp problem? 34 code is common and indicates "lamp abnormality" If you are not clear on how to read the code I believe your owners manual has a section explaining that. If the lamp was blown it is possible the ballast board that provides voltage to fire the lamp is also defective and this may also give you the same error code. I would recommend also that you first reseat the lamp assembly to be sure it is fully plugged in. Also be sure the lamp door is postioned and secured properly (this typically will give a different error code, however) Also try unplugging the unit for a few minutes to reset and try powering it up again. Sometimes this will clear a problem.
Nov 12, 2009 | Mitsubishi VS-55707 TV
When I turn on the TV, nothing comes on. No pictures or sound. Red light comes on where it says lamp. Do I need to replace the lamp. Please kinldy advise . Ty
Yes. You need to replace the lamp. Mine did this when my lamp burned out.
You can try pressing <menu> and <device> at the same time, and you'll get a code flashed out to you (tens digit followed by unit digit). You'll likely see one of the following codes:
  • 34 Lamp abnormality
  • 36 Lamp Ballast or exhaust fan failed.
  • 38 Lamp temperature too high
  • 42 Lamp Fan Failed
But the user's manual and the repair manual both say that a red lamp light means your lamp isn't working (most likely it needs to be replaced).
May 10, 2009 | Mitsubishi WD62627 62" HDTV
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 error code 34
replaced 2 capacitors 3300u/35v. At the power board.
do not tuch the rest of the chassis...............
Nov 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 error code 34 lamp abnomality
the capictor problem is mostly for WS models
you can locate the dm model from this link
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525-Code 34-Sound OK-No picture!
I had another problem kinda the same and emailed and they gave the fix.
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 New lamp-Code 34-Lamp abnormality?
check that you did not bend you connections on the lamp housing
when you reinstalled have seem this happen
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
167 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
