Question about All-Pro Forced Air Kerosene Space Heater SPC-K75
Getting no fuel - All-Pro Forced Air Kerosene Space Heater SPC-K75
  • All-Pro Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 16, 2011
Taotao 50cc scooter will initially start then sounds like not getting gas, cuts out & dies tried fuel cleaner still having problems keeping it running?? Any ideas??
If it acts like it isn't getting any fuel then that may be because it isn't getting any fuel. Often the obvious is the reason and people try to over think it.
Now, why isn't it getting any fuel? Or why is some getting through but not enough to run?
Fuel filter blocked, bent or kinked fuel line, blockage in the tank outlet, faulty fuel pump or fuel tap, fuel cap not venting so a vacuum is caused holding the fuel back, carb issues. There are lots of things to check and eliminate as the problem. Try working through the above list and see if that solves it.
Jul 25, 2015 | Motorcycles
2003. Why is no gas getting to the fuel rail?
Could be a "fuel pump relay" or ford equivalent that converts ECU fuel output demand signal to power to the fuel pump. To test jump direct positive to fuel pump and see if you get pressure at the rail. If you get pressure, that may be part of the problem. If not enough pressure (but measure) you may have a fuel pressure regulator or ford equivalent issue.
Jun 08, 2015 | Ford Ranger Cars & Trucks
No fuel getting to fuel rail.
fuel pressure regulator is what is in between the pump and the rails. it sounds like your regulator is restricting fuel flow
Feb 23, 2010 | 2006 Mitsubishi Lancer Evolution
Getting an EE6 after relocating heater. Have fuel
EE 6 usually indicates a fuel problem. You said you just moved the heater. If the fuel pump is making a loud ticking sound it means it isn't getting any fuel. Try pressing the fuel reset located on the lower right side of the heater. There is a float in the fuel sump that can get latched up so that it will not let any fuel into the sump if the heater is moved or jarred or the sump gets too much fuel in it. You say you have fuel, do you mean in your barrel or is it coming out the fuel line behind your heater? It is possible you have an air bubble in your fuel line that you need to get out. Hope this helps.
Jan 23, 2010 | Rinnai Toyostove Direct Vent Heater:...
Getting a reduced engine power light
Sounds like possible electronic fuel pump failure. when fuel pump gets weaker as the fuel level gets lower . Some folks have a tendency to run their vehicle low on fuel which will eventually shorten the life of the fuel pump.
In some cases you can fill the car up with fuel and the problem will go away in the early stages of the fuel pump problem. The problem comes back as the fuel supply in the tank gets lower. This is one sign.
Nov 22, 2009 | 2001 GMC Yukon
Injectors not getting fuel
i have an 88 chevy truck, not getting gas to come out of injectors.. getting gas all the way through the lines all the way up to the tbi but not out of injectors. pressure gage check done! new fuel regulator done! . u can put gas in the throttle body and it fires right up.??
Nov 16, 2009 | Ford Cars & Trucks
Engine not getting gasoline
CHECK TO SEE IF YOU HERE THE FUEL PUMP START AFTER YOU TURN THE KEY ON. FUEL PUNP, FILTER, FULE PUMP RELAY.
Apr 29, 2009 | Pontiac LeMans Cars & Trucks
94 dodge grand caravan no fuel in fuel rail
Dear Ron, you have replaced fuel pump and fuel filter. You have checked the fuel pump relay. Still no fuel in rail. Try bypassing fuel relay with jumper from batt to fuel pump. If o/k then check computer for ground to relay. This system uses a relay that is operated by the computer that supplies a ground for the relay to operate. The wire color is green,16 gage. If the ground is not available then "no fuel" Check this with a test light. Key on and crank apply test light to ground wire and other end of light to ground. You should hear relay click and get fuel. If this checks out you will need to replace computer or get creative with rewiring the relay so it works without computer input. Good luck Moe
Apr 24, 2009 | 1994 Dodge Grand Caravan
Fuel wont flow
You likely have a bad lift pump in the tank. You are working on the fuel pump on the fuel rail right? This vehicle has two fuel pumps one low pressure and one high pressure.
Mar 28, 2009 | 1989 Ford Econoline
All-Pro Forced Air Kerosene Space Heater SPC-K75 Logo
Top All-Pro Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
1STHVACMAN
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
