Question about Quantum Fireball Plus AS (QMP30000AS-A) 30 GB Hard Drive
I want to install quantum 20 GB lct as my second drive and as a slave. I have a six pin connector at the back. How do i set the jumper so as to make it a slave drive thakx jason
    Brigadier General:
  • 10,406 Answers
Take a VERY close look for some "engraving" near the pins.
Look for 'MA(ster)' and 'SL(ave)' and 'C(able)S(elect)' lettering.
Or, some disk-drives have a diagram on the label on the top of the disk-drive, instead of the engraving. Follow the jumpering-instructions on that label.
Posted on Nov 05, 2010
How do i configure this hard drive for a 'slave' ?
Hello
Ok, you ill be able to see the jumper configuration on the hard drive itself. Here is an example on what the jumper diagram will look like on a hard drive.
Now, all you need to do is to have a look on your hard dive and see where you need to place the jumper for the slave configuration. Here is what a jumper looks like.
After you have done this, you only need to plug the hard drive into your pc.
Hope this can be of help.
Kind regards
Aug 13, 2010 | Quantum Fireball 15 GB ATA-66 Hard Drive
Hard disk not recognized
found the solution inside Dell web page - jumper position shown graphically - Thank you, anyway.
Jan 07, 2010 | Quantum Fireball Lct20 (QML20000LD-A) 20...
What are the jumper settings for a quantum Fireball 20 gb HD to set it as slave
looking at the bottom of the drive where the circiut board is ,then turn the connectors towards you, you will see the power connector , then right next to it is the pin setting block with 5 sets of 2 pins second set from the right edge is slave,put your pin tie on that set and your fine
Jul 10, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Quantum Fireball lct 30gig not recognized in Dell Dimension 3000
Turns out this particular drive needs TWO jumpers on it, to set it to CS. I received it used with a single jumper in the Master position, but after checking the Maxtor/Quantum website, it listed the jumper positions and showed the second jumper. As soon as I installed the TWO jumpers in the correct position, the Dimension 3000 booted right up and let me reinstall Windows. I had scoured the internet for many hours looking for a solution, none solved it until I decided to check the manufacturers website. Always start there!- Solved!
May 18, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Setint the jamper as a 2nd drive and Do i need to farmat it frist
If I recall right this HDD is a PATA (IDE) type. As for the Jumpers please check the following link. The jumper should be as Slave drive.
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
May 15, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Problem putting a 30 gig quantum lct 15 3.5"series as a slave
Did you switch the jumper config back to Master or CableSelect before trying to install them as a single drive? Also check the Maxtor website, (they owned Quantum too), for the correct jumper settings. Some of these drives (like the Quantum Fireball lct series) need TWO jumpers not just one.That was the trick that fixed mine from not being recognized by the Bios or the Windows setup disk....I got it used with only a single jumper, but it needed two to put it Cable Select mode.
Apr 07, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Jumper setting
Jump the middle pins, second set from the right when looking straight on with the power connector on the right.
Worldvet
Nov 17, 2008 | Quantum Fireball Plus AS (QMP20000AS-A)...
Hard drive quantum fireball lct 20
go to quantum website, download manual, check for correct jumper settings
Dec 03, 2007 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Quantum Fireball Plus AS (QMP30000AS-A) 30 GB Hard Drive Logo
107 people viewed this question
Top Quantum Computers & Internet Experts
Marvin
Marvin
John Porter
Alun Cox
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
