Question about Samsung SyncMaster 1100MB 21" CRT Monitor
I have just connected my old (beloved) SyncMaster 1100MB to my new computer with Windows 7. I can only get a refresh rate of max 60 Hz to the monitor. It gives too much flicker. How can I get a higher refresh rate? (My ATI Radeon HD 5670 video card register the monitor as: Standard non-PnP-monitor). Yours sincerely Hagen Jorgensen.
  • 712 Answers
Right click your desktop and select "properties". On the last tab (where you set the resolution) click the "advanced" button. On the new property sheet go to the monitor tab and uncheck the box that say something like "hide modes that this monitor does not support". Click OK then. Now you should have everything up to 200 Hz.
Hope this helps. If you need any more assistance, don't hesitate to come back to me. Else, if the problem is solved, please do ACCEPT this solution. Best Wishes. Thanks for using FixYa.
Posted on Nov 05, 2010
2333 sw modeline
Samsung SyncMaster
Part Number: LS23CMZKFV/ZA
Product Line
Samsung SyncMaster
  • Native Resolution Full HD (1080p) 1920 x 1080
  • Contrast Ratio
    1000:1 / 20000:1 (dynamic)
  • Color Support
    16.7 million colors
  • Horizontal Viewing Angle
    170
  • Vertical Viewing Angle
    160
  • Brightness
    300 cd/m²
  • Horizontal Refresh Rate
    75 kHz
  • Vertical Refresh Rate
    61 Hz
  • Max H-Sync Rate
    75 Hz
  • Max V-Sync Rate
    61 Hz
Dec 18, 2017 | Samsung SyncMaster 2333SW 23" LCD Monitor
Tell me what is samsung syncmaster 794 default setting
The maximum resolution supported is 1280 x 1024 pixels at 65 Hz refresh rate, while the recommended resolution stands at 1024 x 768 pixels at 85 Hz. However, the maximum usable resolution is 1152 x 864 pixels at 75 Hz. Maximum usable resolution signifies the maximum resolution supported by a monitor at a refresh rate of 75 Hz or better. Though 85 Hz is an ideal refresh rate, 75 Hz is the lower limit. Any refresh rate, lower than 75 Hz, will give a flickered output and can cause some serious eye damage after prolonged usage...i hope this helps.
Aug 29, 2011 | Samsung 793DF 17" CRT Monitor
Unable to get 1024 x 768 resolution on philips 105e
Hello, that resolution should be available but only at a refresh rate of 60hz as per the specs pasted below. Can you see this resolution setting on your graphics card? If not then perhaps you need to check you have the latest driver for your graphics card and just make sure that your graphics card does support that setting anyway.
Display
Diagonal Size 15" Viewable Size 14" Dot Pitch / Pixel Pitch 0.28 mm Max Resolution 1024 x 768 / 60 Hz Max Sync Rate (V x H) 120 Hz x 54 kHz Video Bandwidth 65 MHz Factory Preset Resolution Modes 1024 x 768 / 60 Hz
800 x 600 / 85 Hz
640 x 400 / 70 Hz
640 x 480 / 75 Hz
640 x 480 / 60 Hz
800 x 600 / 75 Hz
Regards,
nicam49
Dec 26, 2010 | Philips SoHo 105E 15" CRT Monitor
I have a Mag Innovision 2200W Monitor. I messed with the settings, and now I get a ''mode not supported'' error. The computer is running in the background, and works with other monitors, but not this one....
Hi
To resolve this issue connect a monitor which is working with the Computer. Now right click on desktop and select properties(if windows XP) or personalize/screen resolution (if windows vista / 7)-> Now click on settings tab (windows XP) or change the resolution of your monitor-> Choose a lower resolution rate maybe 800X600. Now try connecting the other monitor with your Computer and it will work.
If not then check for the refresh rate of your monitor, adjust it to 60 Hz. You can adjust refresh rate from settings tab->advanced button(in XP). Screen resolution/Display settings(under windows 7/vista)->Advanced setting->monitor tab ->refresh rate.
This will surely resolve your issue.
Daniel Scott
Jun 08, 2010 | Computers & Internet
I have a Samsung SyncMaster 901B, it's not new, a friend gave it too me, i connected it to my computer,i start the computer, it works fine until windows finishes loading, then the screen goes black and i...
What happen when you hook this monitor up to other PC that has the video setting 1280 X 1024 60 Hz? Just ant to narrow down the problem before opening up the monitor. You may have logic problem in the logic board. If it does the same with other PC, then open it up and inpsect the inside for such thing as failed caps on the logic board or on the main power supply board, I think more likely to be ROM chip on the logic board is scrambled.
See typical failed monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 30, 2010 | Computers & Internet
Too much screen flickering @ 1024x768 (60hz)
setup your monitor driver supplied with the monitor, you will get more options. Thanks
Oct 29, 2009 | Computers & Internet
MGA 1164SG R3 video card work
You can connect it to your old monitor. As a safe method before connecting the lcd monitor to the old system go to ---- control panel --- display. Double click on it and select settings ----- advanced
Here select - monitor---->monitor settings ---> screen refresh rate. Select a low refresh rate (60 or 70,72). Press apply then ok.
Switch off the pc and remove the old monitor and connect the lcd monitor. It will work.
Nov 12, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
and
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
TFT Problem
This LCD can work at 75 Hz refresh rate, btw much more healthy for your eyes, you can change it accessing Control Panel -> Display -> settings -> Advanced -> Monitor -> Screen Refresh Rate -> select 75 Hz.
Dec 07, 2007 | Samsung SyncMaster 152N 15" LCD Monitor
Samsung SyncMaster 1100MB 21" CRT Monitor Logo
99 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
