Question about Exercise & Fitness
EverYoung 75900 needs to be reprogramed Display unit show F1 can you pls provide the code thanks Joanne Pekar
Original price for treadmill 75900F?
Posted on Jul 27, 2013
I have a problemwhen i start the ever young model 75900F
on screen F1
please send me solution
Posted on Apr 22, 2011
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
My stove not working and shows f1
Hi mannycarla - Typically error code F1 indicates that the range has detected an issue with the runaway temperature (overheating). A certified technician will need to check the RTD senor probe and/or EOC and replace if necessary. Meanwhile try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart range. Usually this will clear most false error codes. If it proves to be ineffective, contact a professional to move forward accurately.
Feb 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Shows f1
Hello mannycarla - Typically error code F1 indicates that the range has detected an issue with the runaway temperature (overheating). A certified technician will need to check the RTD senor probe and/or EOC and replace if necessary. Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart range. Usually this will clear most false error codes. If it proves to be ineffective, contact a professional to move forward accurately.
Feb 07, 2013 | Frigidaire Gallery 30" Self-Cleaning...
F1 code
Most F1 error codes refer to a communication error in the main control board/ clock on some there are reset overload switches that if tripped show as a push button that is pushed outward that you can reset. This also mainly depends on which type of oven that you do have and you would have to provide the make and the model number of the unit in order for me to give you an exact solution to your f1 error instead of a generalized one. Sometimes also you can turn off the power at your electrical breaker for 7 minutes which this causes the control to reset in some. Most of the time in most models though the F1 refers to having to replace the electronic control module (ECM. If you have any further questions or wish for me to look up the exact error for your unit message me back your make and model number and I will give further diagnosis on your unit. Thank you again
Rick
Nov 26, 2011 | Ovens
I have 2 Panasonic wireless phones ModelKX-T7885 and a panasonic PBX. One wireless phone will not display F1 thruF4 lines; it displays F9 thru F 12 only depspite reprogramming the unit to default settings....
Hello, Peter.
Try resetting your modem / router that provides the connectivity.
Then, if necessary, re-power (Off and leave for 10 minutes, then On) your phones.
Hope this helps.
Sep 15, 2010 | Panasonic KX-T7885 Cordless Phone
What does error code f1-4 mean?
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Dec 30, 2009 | Maytag Kitchen Ranges
Top burner is stuck on and F1 showed on the display
Hi Krista,
Unfortunately, F1 is a fault code for a failed electronic control... it'll have to be replaced. The reason the burner is on is that the relay controlling it has welded closed allowing power to the burner full time.
If you choose to repair this yourself, could you provide the model number? That way, I could pull up schematics and stuff I need to further help you.
SG
Apr 05, 2009 | Kenmore Ovens
My kenmore kitchen range has a glass top w/4 burners; 2 oven racks w/ 1 extra in the bottom (3) total; black top,front and top control area w/lcd display. i found it off and when i tested the circuit...
It sounds like your little Computer has lost its settings, and needs to be reprogrammed, you need your manual which came with this Range to do it yourself, or you need to call in a service technician.
It wont be too expensive,because it can be re sett pretty fast.
Jan 29, 2009 | Kenmore 92320 / 92321 / 92322 / 92324...
My oven is beeping!
F1 Circuit board defective Replace control board
Good Luck and Please Rate Fixya!
Jan 07, 2009 | Electrolux Frigidaire Professional Series...
F1 code on Fisher and Paykel dishdrawer
It would seem to be in an endless loop (firmware glitch). Initially, pls try:
  • unplug from the mains or switch off the breakers for a couple of minutes;
  • plug back in/switch on the breakers say after 20 minutes;
  • press POWER to turn drawer on;
  • Press and hold (at the same time) both the POWER and ECO buttons for a few seconds;
  • a five minute demonstration wash cycle will come on;
  • press POWER again to put unit on standby, all the LCD segments will start flashing (and light up);
  • press and hold START/PAUSE for a few seconds to hear confirmation beep/tune.
Alternately, should you have the two-drawer, open any drawer and look at the wash intensity/economy buttons. Now press them, one at a time, alternating between the two, at even timing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Exercise & Fitness Logo
224 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
