Question about Pioneer Audio Players & Recorders
I have a Toyota Scion with a Pioneer T1805 that is giving me a Error 4 Message perodically which does not allow me to use the CD player. Help Please!
  • 2,071 Answers
The most common problem of error messages is the lense and the roller.The roller is that moving back and port bringing the lense set,had already many dirt,that stock up of moving the roller.You better take out the unit from your car and open it .You clean the roller by using a lighter fluid or desame kind of that fluid and clean the lense with a cotton buds ,soak the cotton buds with a little plain water and after that , use a dry cotton buds to dry it out and in the roller take the old grease in the roller and replace it with a new grease .Use a type-A class grease.If you finish this all,i assume you that performance will be better.
Posted on Jun 17, 2008
How do you fix a stuck volume button on scion xb stock stereo?
The only way to fix it is to take it apart and see if it is just jammed or if the button is defective if defective you neeed to replace it they are very small so you need some good soldering skills. Hope this helps.
Aug 21, 2014 | Pioneer 2005-2006 Scion Tc Xa Xb Cd Mp3...
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
I KEEP GETTING AN ERROR 4 ON MY STEREO.
Try using a cleaner if that does not help then your other options would be to service it or get a new stereo
Jul 14, 2009 | Car Audio & Video
Scion xa radio - T1805 volume button stuck
I have a 2005 Scion XB radio system. The volume down button is stuck in and won't work. I tried to "pry" around it to try to free it, but it's like there is a spring inside that is missing. How do I repair this.
Thanks in advance for your help!
Apr 20, 2009 | Pioneer Car Audio & Video
Can a 2006 Scion Tc cd player fit into a 2005 Scion Tc?
yes its the same plugs but you wont have the steering weal control
Jan 17, 2009 | 2005 Scion tC
Power IC Damaged Displayed
if it displays "power IC damaged ,your CD player is as good as DEAD.
For giving it a new life ,take it to PIONEER SERVICE and get the IC replaced and any other repairs that may be needed.
Jul 24, 2008 | Pioneer DEH-P80MP CD Player
When I try to play a C.D. on my system it gives me the following information. FRMTREAD, Error 15. What does this mean and what do I do to correct this problem? My system is a DEH2000MP S.N....
Consult your owner's manual for error codes. You have a disk/disk reader problem. A similar model Pioneer Manual indicates FRMTREAD as what is displayed while reading a disk. Error 15 equates to "The inserted disk does not contain any data". If this occurs with multiple disks, try the disks in a known good cd player. If they work there, it is likely a reader problem (alignment, bad reader, etc.) which would likely not be worth repairing or replacing in that unit.
Jun 23, 2008 | Pioneer DEH-P2000 CD Player
Help
I'm having the same problem. I get an error message for the first cd, but will play ever other cd.
May 17, 2008 | 2003 Toyota 4Runner
Error 4
hi what model is the pioneer unit?
Mark
www.blueice-electronics.co.uk
Feb 17, 2008 | Car Audio & Video
196 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
