Your console is an old one,and your lens too is probably weak.Try cleaning your PS2 lens Watch Video at end of solution to clean your PS2 at home.... You can also follow these steps to make your PS2 to play GTA San Andreas:
Turn on your PS2 without inserting any disc.
On menu screen go to [options] by pressing 'triangle' button.
A new screen will appear select by pressing 'X' [DISC SPEED]and set it to [FAST]
Then insert the game disc.
Turn off your PS2.
Press and Hold the [Reset Button] till the blue light turns on.Release the Reset button and press it again.
It will take a bit more time to play game,but first i recommend you to clean your PS2 lens,watch this video.
I've got something else to add.......you can follow above steps to play DVD movies if your PS2 dont play any.....!!!
A couple things come to mind. If the lens is dirty, then there will certainly be issues with load times, or load failure. Check your game discs for scratches and scuffs. If a disc has a scratch or too many scuffs on it, it will make it difficult for the laser to read. Clean your discs, and clean your ps2 lens with a basic ps2 laser cleaning kit. You should be able to find them anywhere. I don't recommend cleaning the lens without a kit if you are not familiar with the internals of a PS2 or cleaning electronic components. If after cleaning your disc and lens it still gives you issues, there is an angle adjustment gear in the ps2, but we'll cross that bridge only if the cleaning doesn't work.
its a ps2 problem open the ps2 up if its a big ps2 not a mini and dust it the dust is making it harder for your ps2 to read disks open it dust it and itll be like barnd new if its a small ps2 i dont know dusting the thing always help dust with somthing small a cotton ball or ear swab will work
Is this a new problem or has your PS2 always had this issue?
You cannot adjust the laser at all and are likely to damage it if you try, you can however clean the laser lens with a CD/DVD cleaning disk and you'd be surprised how often this resolves disk read issues.
Some of these units did have a production fault that prevented them from reading DVD's, if your PS2 has had this fault since new and/or is under 12 months old you could probably have had it repaired/replaced by Sony but by opening it you will have invalidated you're warranty.
