Question about Lexmark X5470 All-In-One InkJet Printer
The printer is not taking in the paper but i can hear it run. error message "load paper in paper iput tray" keeps cropping up even when paper is taken out and reloaded
  • 712 Answers
Try a new set of paper after removing the ones which was already exposed to air for long. Also, please notify me about the outcome.
Posted on Nov 05, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Error message is " paper
Check for a tiny piece of paper or some toner that may be covering a sensor.
Jan 07, 2011 | HP LaserJet P2055d Printer
Paper is inserted properly but error message keeps saying "Load paper face down in Main tray"
i think the printer has 2 trays, one down and the other one on top from where you insert the paper. load the paper there as well. if there is only one tray then check the paper sensor in the bottom, if the paper end sensor comes out of position then it will not detect the paper.
Jan 06, 2011 | HP Photosmart C6280 Printer
Printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 18, 2010 | Panasonic Workio DP-3030 Printer
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere?
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Sep 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error Code C0960
That error code usually indicates a problem with the bottom paper tray. Make sure the paper is loaded properly and that all the paper is aligned properly. Take all the paper out of the tray and reload it.
Dec 06, 2007 | Minolta Di3510f Bizhub Copier
Constant "load paper in tray" error even when paper is loaded.
Contacted HP CEO, office getting some interest now!
Re bad paper feeder Did not use main tray feeder until now!
Nov 30, 2007 | HP Photosmart 3310 Printer
Lexmark X5470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
