Question about Advent Netbook
Hi ive got a advent netbook and its sayin bootmgr is missing,but befor that i got <windows root>\system32\hal.dll. is corrupt or missing how do i fix this prob ive tried with the techguys by trying to reinstall and it keeps saying error please try again and i do and still no good plz help me thanks
    Guru:
  • 261 Answers
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully. 8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
Posted on Dec 24, 2010
My acer one has no cd rom and has an error report windows could not start because the following file is missing or corrupt <window root>\system32\hal.dll please re-install copy of the above file
You need to repair your windows, with either using Recovery or get the external CD then reinstall operating system. Hal.dll usually still in your system32 folder but corrupted..
Aug 05, 2011 | Acer Aspire One PC Notebook
Notebook says that windows could not start because the following file is missing or corrupt &lt;windows root&gt;/system32/hal.dll.
Causes of the missing or corrupt hal.dll error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
To fix it:
1) Restart your PC, sometimes the hall.dll error could be an error itself and your PC should boot up fine.
2) Go into the BIOS by pressing the Delete key as the laptop boots. Then navigate to disk boot priority and make sure this is set to your main hard drive (the one that has Windows installed on it). Save and exit the BIOS. Sometimes if you have a USB flash drive/Pen drive or external hard drive it may automatically switch the boot priority to that.
If these two quick steps don't fix the problem then head over to here and continue reading up about repairing the boot.ini file.
Mar 10, 2011 | NEC PKM35-4A33 Buzzer (802870018009A) PC...
On start up <windows root>/system32\hal.dll.
Your Hall.dll is fine but you have to repair it.
ATTRIB C:\BOOT.INI -a -h -r -s
DEL C:\BOOT.INI
BOOTCFG /rebuild
FIXBOOT
Jan 17, 2011 | Acer Aspire One PC Notebook
Windows could not start because the following file is missing or corrupt: &lt;windows root&gt;\system32\hal.dll. How do i fix it?
hi, right you need to boot up using your windows disk, change the boot order so it picks your DVD drive first, now select repair once windows starts up.
Regards
GeWiz.
Please rate this if it helps.
Dec 18, 2010 | Acer Aspire 1640Z Notebook
HI MY ACER ASPIRE 5612 WILL NOT OPEN BECAUSE THE FOLLOWING FILE IS MISSING OR CORRUPT &lt;WINDOWS ROOT&gt;\SYSTEM32\HAL.DLL.
Read this
http://pcsupport.about.com/od/findbyerrormessage/a/missinghaldll.htm
and follow the troubleshooting protocol. If you don't know how to do that then just reinstall Windows.
Nov 09, 2010 | Computers & Internet
How to solve this problem <windows root>\system32\hal.dll.
Hi
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
1.Insert and boot from your WindowsXP CD.
2.At the first R=Repair option, press the R key
3.Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
4.Type bootcfg /list to show the current entries in the BOOT.INI file
5.Type bootcfg /rebuild to repair it
6 Take out the CD ROM and type exit
OR
Better solution: This seems to always work
expand x:\i386\hal.dl_ y:\windows\system32\ X= cd rom drive letter
Thanks and Regards Aboobacker S
Sep 23, 2010 | Microsoft Computers & Internet
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Missing windows root system32\hal.dll
Hi
There are few different ways that the "missing or corrupt hal.dll" error may present itself, with the first listing being the most common
Use the following links
http://www.computerhope.com/issues/ch000490.htm
Note: if the repair is not successful then you would have to redo the entire OS. This would mean data loss on the computer.
Thanks for using Fixya
proton
Aug 15, 2009 | Acer Aspire One PC Notebook
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Windows>\system32\hal.dll. corrupt
HAL.DLL Missing or Corrupt
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
Advent Netbook Logo
196 people viewed this question
Top Advent Computers & Internet Experts
Computer Links
Rajendra Singh
Rajendra Singh
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
