Question about Mitsubishi WS-55859 55" Rear Projection Television
Reset Proceedure How do you reset this tv? It won't stay on but three seconds. Does it sounds like a goner?
  • Mitsubishi Master
  • 8,617 Answers
Un plug the set from the wall for a few minutes then plug back in. If that doesnt help you will have to trouble shoot the set.
Posted on Jun 17, 2008
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
How to get change oil light to go off
Instructions:1) Check the oil. The light is a warning signal that you are low on oil or that the oil is not flowing properly. If the oil level is fine then the issue may be a reset button. Two different methods will allow you to reset the oil light.2) Turn the key to the on position. Do not turn the engine on. Press the accelerator pedal down three times in a five-second period. Turn the engine on. If the oil light goes off you have successfully reset the oil light. If it stays on you need to try the second method.3) Find the fuse box. This should be under the dash in between the steering wheel and the door. Open the fuse box and look for the reset button. Press the button until you hearing a beeping sound. It will beep three times. The oil light should be reset. Turn the engine and see if the oil light goes off. If the oil light stays it still has not been successfully reset.
4) Read the manual. The two methods above are the two most common ways of resetting the oil light. Your car may have additional options to try. If none of the methods resets the oil light then there is a different problem such as a non-functioning oil sensor. At this point you need to see a mechanic.
Parts Of BMW.
May 30, 2012 | 2005 Dodge Magnum
My brother's PS3 on my non-HD tv. We tried connecting and getting different S-video cables but it still won't show up anything. We know the input channel is correct, it just won't show. My...
Yes the display settings need to be reset since he had HDTV and you don't. I do this by simply having the PS off then press power button and hold it for 5 seconds.
Jun 09, 2011 | Sony Playstation 3 (PS3) Console
I need to reset my password on my rca HD52W55
Hello
If your RCA tv has locked or you want to reset your password you can opt any one of the followinf option to unlock it without any passcode nd can reset it after.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won
May 06, 2011 | RCA Televison & Video
How do I turn off the service vehicle soon light. and what does it mean. It turned on after I got an oil change.
If you are refering to the maintenance reset proceedure for the oil service light, it is generally reset by turning the key on and depressing the accelerator pedal to the floor either 3 times slowly within 5 seconds. If the light flashes and then stops then it is reset, if it does not repeat the proceedure. If the Check Engine light is on, it requires a scan tool to reset the light.
Jan 19, 2011 | 2001 Pontiac Aztek
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Lamp light
If you still need code i have it at shop i am home right If i rember right you must reset lamp Timer to Tell tv that it old lamp has been replaced with new code is 9,8,7,6, ect...........
Jan 17, 2008 | Zenith E44W46LCD 44" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
