Question about Acer Aspire 5520-5156 Laptop
My aspire 5520 tries to turn it on, in kind of loop, without success. It keeps dark screen and there is no bios access available. The 'ON button' and the 'HD led', both keep 'on' for around 3 seconds, then turns off and repeats but the computer does not work keepin dark screen, then it is impossible to turn off, it must be unpluged.
    Sergeant:
  • 248 Answers
Hi, Every PC-Laptop has BIOS otherwise nothing would work at all. Try turning the PC on & hold down ALT & F4 together that should get you into the BIOS. As far as having no display then your Video card must be not working & needs replacing. Please leave me feed back: Malcolm Campbell, Thanks.
Posted on Nov 06, 2017
5 Suggested Answers
SOURCE:
  • 4090 Answers
SOURCE: Can't turn my lappy on
Damaged Bootstrap You need to take it for repair
Posted on Aug 16, 2009
  • 17 Answers
SOURCE: keeps restarting
CHECK WHEATHER SYSTEM IS BOOTING OR NOT GO TO BIOS CHECK WHEATHER HARD DISK IS DETECTED OR NOT.
Posted on Sep 09, 2009
  • 1481 Answers
SOURCE: acer aspire 5520 endless rebooting problem!!!
the registry is corrupt...this happesn after frequent use and windows files getting corrupt...
get Tuneup Utility and crack from my website and install both the software and crack then clean the registry using the tools in there...
go to Download page in
www.sureshayyar.110mb.com
Posted on Dec 26, 2009
joecoolvette
  • 5660 Answers
SOURCE: when i press the power
Start with cleaning the laptop's air intake duct. It may be dirty enough that the Processor overheats from lack of airflow. (Which cools it)
A Processor heats up as it operates. Air flow from the laptop's cooling system keeps the Processor temperature within a specified range. (Thermal Limit)
When a Processor overheats it turns off. (BIOS turns it off)
This is a built-in fail safe feature to keep the Processor from burning up.
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire6920/Aspire6920sp2.shtml
Looking at the bottom of the laptop with the Front facing away from you, (Battery Compartment towards you), the air intake duct is the square grille on the bottom Left.
1) ALL power removed from the laptop. Remove the Battery, and AC adapter (Charger) if plugged in.
2) Buy a can of compressed air for computers.
Insert the plastic straw provided into the nozzle. Break the plastic lock tab off of the top of the nozzle.
3) Lay a towel on a table.
Hold the laptop up on edge, so that the air intake duct is closest to the table.
You may wish to use a helper for this.
Spray air into the air intake duct. (NOT the exhaust duct on the side)
Hold the straw close to the grille, and spray across the top of the grille opening.
Use Short Bursts.
Squeeze the trigger in all the way, then let go quickly.
You do Not want to spin the fan (Cooling Fan) faster than it was designed for.
Spinning the fan too fast may result in premature failure of the fan's bearings.
(If you hear the fan go 'Zing', back away with the straw from the grille opening, and/or use a shorter burst of air if possible)
Keep moving down in rows, and spray across. You may wish to use a flashlight, and peer into the air intake duct. See what kind of progress you have made.
When using the can of air you are not supposed to tilt the can.
This could result in some of the propellant coming out.
It is inevitable that the can will be tilted during the cleaning process. Don't fret about it.
Set the air intake duct edge of the laptop up on a book, so that if there is any moisture present from spraying air, it can dry out.
Allow 10 minutes for drying before reinstalling the Battery, and AC adapter.
Once power has been restored for the laptop, let the laptop sit for 1 minute before turning on.
Still no?
The laptop's cooling system is the air intake duct, a cooling fan assembly that draws air into the air intake duct, a Cooling Tube, and a Heatsink.
Typical construction of a Heatsink is a plate of metal with tall, thin fins protruding from it.
The plate of metal absorbs heat from whatever object it is placed against, and the tall, thin fins absorb heat from the plate of metal.
The Cooling Tube is a slightly flattened copper enclosed tube. It is filled with Nitrogen. At one end it has two plates of metal attached to it. One plate sits on the top of the Processor's case, the other plate sits on the GPU.
GPU = Graphics Processing Unit. It is the 'graphics engine'. It is an I.C.
Integrated Circuit, or commonly referred to as 'Chip' or Chipset',
http://en.wikipedia.org/wiki/GPU
The two plates of metal absorb heat from the Processor, and GPU, and transfer the heat to the Cooling Tube. The Cooling Tube has a Heatsink at the other end.
The heat is then transferred from the cooling tube to the Heatsink.
The Heatsink is attached to one side of the Fan Assembly.
The air flow from the fan assembly helps to carry heat away from the Heatsink.
The Acer Aspire 6920 has two Cooling Tubes, which each one has an aluminum plate.
One cooling tube is for the Processor, the other cooling tube is for the GPU.
Allow me to show you the cooling system of a Acer Aspire 6920,
http://notebookitalia.it/recensione-acer-aspire-6920-10.html
The larger aluminum plate (Looks like a meat tenderizer with the protrusions that stick out), is for the GPU. The smaller plate is for the Processor.
Point of all this?
It may be that using a can of compressed air on the air intake duct from the outside, just won't do it.
The laptop may have to be disassembled far enough to physically remove the 'Gunk' that has built up.
('Gunk' = Dirt, dust, hair, food crumbs, etc.)
Use a small, SOFT brush, Q-tips, and compressed air, to clean the Heatsink, Fan Assembly, (Fan, and surrounding shroud), plus clean the air intake duct passageway.
I would also suggest removing the Cooling Tubes, THOROUGHLY cleaning the top of the Processor's case, and the bottom of the plates attached to the Cooling Tubes.
Use an old credit card to scrape off the old thermal paste, as best as you can.
Follow with Q-tips dipped in Isopropyl Alcohol.
CAUTION!
Isopropyl Alcohol is EXTREMELY FLAMMABLE!
Use in a Well ventilated area with NO sparks or flames present.
If you find that the Thermal Paste has dried up, there is most of your problem. If the cooling system, and rest of the inside of the laptop is dirty, there is the other part of the problem.
80 percent of computer failure is the computer is dirty inside. If you have never had your laptop cleaned, your laptop is a good candidate for this type of failure.
Thermal paste dries up over time. Thermal paste also looses it's conductivity properties over time.
(Heat conduction)
The top of a Processor, and the bottom of a Heatsink are not perfectly smooth.
(In this case the bottom of the two plates which sit on top of the Processor, and GPU)
A magnified view would show, 'Pits, Hills, and Valleys'.
When the two parts are mated together, (Processor and plate, and GPU and plate), there are air pockets formed from the above mentioned imperfections.
Air is an Insulator, Not a Conductor.
Thermal paste fills these voids (Imperfections) and is an Excellent conductor of heat.
(Transfers the heat from the Processor, and GPU, to the metal plates attached to the Cooling Tubes)
This is a link to a free Service Manual for the Acer Aspire 6920 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the heading that begins with Aspire 1200.
Go down to the 9th line in this 'paragraph'.
Left-click on 6920.
This is a PDF file. It may take up to 30 seconds, or more, for the first page to come up.
It may also take additional time for the file to fully download.
Allow the file to fully download before looking through it.
Need guidance in disassembling post in a Comment.
(ALL power removed. Observe Anti-Static Precautions. Use an ESD wrist strap connected to a good ground source. Average cost of an ESD wrist strap is around $3 to $5.
Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s come out of.
There are screws which are similar to others. DO NOT mix them up.
If no multi-compartment container is available, you can use a clean egg carton as a substitute.
Label each egg holder.
The CTO Cover is removed to gain access to the Fan Assembly, and Cooling Tubes )
Regards,
joecoolvette
Posted on Aug 20, 2011
How do i fix a acer aspire 5520-5912
Hi
You have to re-install windows and the drivers its the only way to get rid of this virus unless this virus is a bios one then, you will have to google it and see if there is a solution for the bios virus.
but try rei-nstalling first.
cheers
Nov 27, 2012 | Acer Aspire 5520-5908 Notebook
I have an Aspire 5520 it all starts fine but after a few mins it flicks over to a blue screen and then reboots but is unable to find any thing apart from the GFX card and just keeps trying to boot from GFX...
Hi, Thank you so much for giving so much information... But can you please tel me the operating system that you are using. and also the exact blue screen code it will be something like 0X00000000ED (unmountable boot volume)
Please get back to me once you see this message :)
Nov 06, 2010 | Acer Aspire 5520-5908 Notebook
Aug 16, 2009 | Acer Aspire 5520-5908 Notebook
Acer aspire 5520 laptop. Is it dead?
To verify it isn't a battery issue you can try taking the battery out completely and plugging in the A/C adapter and turning it on.
Without more information it's hard it's hard to diagnose your issue more specificially. Do you get any lights on the front?
Jun 21, 2009 | Acer Aspire 5520-5579 Notebook
My aspire one does not boot,the screen is dark
Foollow the steps below to resolve the problem. Worked for me. It should work for you as well.
Product
Aspire One 8.9
Issue
No Display / System will not POST Aspire One AOA. Download
http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip
Solution
Create a recovery USB drive to update the Bios on the unit. The specific steps to perform this recovery with the USB drive are:
  1. Download & Extract AS1_BIOS_3309.zip
  2. Rename the Bios name from 3309.fd to zg5ia32.fd.
  3. Copy zg5ia32.fd and Flashit.exe to USB flash drive.
  4. Start the restoration process:
    A. Plug the AC Adapter into the unit.
    B. Insert the USB flash drive into a USB port.
    C. Press and Hold down the Fn and the Esc keys together.
    D. Keep these keys held down and press power.
    E. When the unit's power light comes on release the Fn and Esc keys.
    F. After the keys have been released the power light will start to blink.
    G. Let the unit run and after approximately 1-7 minutes, the unit should reboot.
    H. Video should now be restored.
Mar 05, 2009 | Acer Aspire One PC Notebook
Acer aspire 5520 start up screen
can you go to bios? load default setings in bios, or optimized settings, then try... when something like that happens i usully pull out batery on mother board, than wait about few seconds and pul it back in... bu that is to much work. try above,, and let me know
Feb 15, 2009 | Acer Aspire 5520-5908 Notebook
Acer TravelMate 5520 is bio-probtected and unknown password
Try This:
http://www.computerhope.com/issues/ch000235.htm
Feb 14, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 5520
check if dvd drive will eject if not
if it doesnt - try another socket
if still gets nothing - change fuse in plug
if same - try another power adapter (preferably from same manufacturer and model)
If still doesnt get power try get new power supply unit from repair shop or get quote for cost to fix
Jul 20, 2008 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5520-5156 Laptop Logo
118 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
