Replace keypad gateway w340ui - Computers & Internet
  • arun85 Apr 24, 2009
    HI, I have a Gateway MT6840 .
    My Laptop keypad has a broken key(A) and not am searching for a replacement of the Keypad for the Gateway laptop.
    Could you please help me in finding where i could find the replacement keypad for my laptop.
    Thank you.
    Novelist:
  • 150 Answers
The gateway w340ui is a LAPTOP if I am correct.
Please refer to my other posts on the topic of replacing
laptop keyboards, if you can find them for detailed
INFO common to most laptops.
Every laptop is different, and the first challenge is to find
and download a disassembly manual from the WEB.
You want to GOOGLE for the keywords:
Gateway w340ui Disassembly
Many people put up diagrams and instructions for free.
If this fails, the look to D/La service Manual, which will give
you all the info you will ever need plus some, bu it may
cost a few bucks. $15 is reasonable, $20 is pushing it.
Anything over that is a scalper.
Most keyboards are easy to replace, but the challenge is
getting the cabinet opened. The disass'y manual will be a
great help.
1) Shut down Windows
2) Turn off the PC using the power switch.
3) Unplug all the cables and remove the main battery
(This step is very important)
4) Press the power button again as if trying to turn the
PC back on. This should drain any remaining power in
the internal capacitors, but give it a few minutes just to
be sure.
5) Now you need to get the top off. This may require removing
all plug-in gadgets, floppy, CD drive, Internal Hard drive...
etc. to get at hidden screws from below....
or there could be hidden clips and catches from the top.
There may even be a single hidden screw near the
keypad's perimeter, underneath one of the keys,
which will allow the keyboard to slide out.
Sometimes you can slide a very small and thin exacto
knife in-between the plastic body sections to see where
the binding posts are.
6) Once you have physically plucked out the keyboard or
remove the top cover, you will see a very thin ribbon cable,
(transparent, thin, flexible printed circuit) connecting the
keyboard to the main board.
7) This cable is extremely fragile and very tightly inserted
into the edge connector.
It can be very hard to take out and even harder to put back in.
8) When removing it use long, hooked needle-nose pliers,
and gently tug at each side of the cable until it comes
out. Wrap some soft tape over the pliers to make sure
you don't damage the printed circuit on the ribbon
cable. Take you time !!!!!!
When putting it back, alignment is very critical, and you
have to use the pliers to bend the cable so it is perfectly
aligned and parallel to the connector. It will NOT go in
at an angle or if it is not in the same plane as the
connector. Don't FORCE it, but it has to go all the way in.
Hooked plastic surgical clamps or tweezers also work,
but always wrap something soft around jaws:
tape, rubber tubing, etc.
Hope this helps,
place rate my answers.
Martin
Posted on Jun 14, 2008
How dissambling gateway w340ui
watch this:
http://www.youtube.com/watch?v=CMo6_0mkEE8.
Mar 11, 2012 | Computers & Internet
I have a gateway laptop W340UI/MT3705 that is booting up but the screen is black and yes seems bad to me. But attaching an external monitor brings up everything normally. Could there be a loose...
the computer should least display anything when malfunction were present. Also, the computer would provide message details of the condition if any suddenly were encountered. Observe the computer for any new features thought as unusual. Consult with technitians
Feb 09, 2011 | Gateway MT3705 Notebook
I have a Gateway W340UI. powercord connection
When you wriggle the plug in the power socket on the laptop and the charge LED flashes and in the right position it charges, this indicates that the power socket is faulty or there is a dry solder joint on the motherboard where this power socket is attached.
To get at the power socket will require dismantling the laptop completely. A computer repair shop can do the repair, I suggest you get a quote first.
Sep 03, 2009 | Gateway Computers & Internet
MT3705 Fan broken
wow this is quite the job you are undertaking but can be done, as far as amanual to take this aparty the only way i know to get one is through gateway themselves and good luck with that, having said this i took apart my laptop and replaced the fan but it wasnt easy and theres a bout 100 screws
Aug 31, 2009 | Gateway MT3705 Notebook
Gateway MT3705, model number is W340UI. How do I disassemble it?
Go to any good office supply store and buy a tin of compressed air.
Or go to a spray shop who use oil free lines.
Take the battery out and give the machine a good long blast
Better still take off the main covers underneath before you do so
Make sure that you do not use any air supply that has oil or water in it
Aug 24, 2009 | Gateway MT3705 Notebook
W340ui LCD Display out
some laptops do get shorts in the cables from opening and closing all the time
Aug 21, 2009 | Gateway 450ROG Notebook
I also need instructions on how to open the case for this machine
Hello bmalachowski,
(Yes, another web link!). Here's a link to the pdf version of the user guide. Hopefully, you'll find useful information for opening the case: http://assets.gateway.com/s/Manuals/Mobile/8512150.pdf
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 02, 2009 | Gateway MT3705 Notebook
Lcd screen blacks out when i open my laptop up more than 90 degrees. it's a gateway w340UI. Model # MT3707 I'm assuming it's a pinched or stressed wire but I don't know how to dissasemble JUST the screen...
find sticker lugs on screen,remove and you will find screws.before you do this you need take keyboard off as screen cable is attached to motherboard under keyboard.need to remove keyboard first.there are 2 screws connected to the bottom part of laptop.remove as well.
Jun 24, 2009 | Computers & Internet
Computers & Internet Logo
2,216 people viewed this question
David Payne
David Payne
