Question about Canon ZR85 Mini DV Digital Camcorder
Canon zr85 will not power up, check charger, has power
  • blkmike64 Jun 24, 2008
    no camera, won't power up at all
  • Tim Babcock
    Tim Babcock May 11, 2010
    Does the camera run normal when it is plugged into an electrical outlet?
  • Canon Master
  • 2,794 Answers
You should probably take it to the camera shop and see whats going on with the power supply.
Posted on Jun 24, 2008
Power battery
is the unit charging but you cant see the light for charging or it's not charging at all?
Sep 24, 2013 | Canon ZR85 Mini DV Digital Camcorder
My canon zr85 mini dv camcorder the screen is black when on record even if the side screen is close the eye unit is also black.
It is known problem of ccd imager chip failure in Canon ZR85 camera and ccd imager chip will be replaced to fix the issue.
Local camera repair shop will help you to replace ccd imager chip because solder work is involve.
Jul 21, 2010 | Canon ZR85 Mini DV Digital Camcorder
Zr85 camcorder will not turn no lights no power
Ok, let's try the "easy fixes" first. When this problem happens, it can be a oxidized power switch contact, or oxidized battery contacts on the camera. Clean the battery contacts and the contacts on the camcorder with an eraser gently (they are gold plated). See if the camcorder works now. The next step is only if you're not planning on taking the camcorder apart. There are times when you can give the camcorder a slightly hard "whack" with the palm of your hand, somewhere near the power switch, while the power switch is on, and if the camera works, then you know it's most likely a dirty or oxidized contact inside. See if you can get it working with these methods. If you can't, you will have to disassemble the camcorder or have it serviced. Get an estimate if you get it serviced, since it can be expensive, and you might just opt for a replacement.
Apr 23, 2010 | Canon ZR85 Mini DV Digital Camcorder
My canon ZR85 Digital Video Camcorder will not record and you can not view anything through the viewfinder or on the screen. Both are black. I can play tapes but can not record anything.
I had the same problem and canon fixed it no charge,there was a recall on this check out the link and follow the instructions
Feb 06, 2010 | Canon ZR85 Mini DV Digital Camcorder
Computer reconized canon zr85, but not the zr800
load or reload the drivers for the zr 800,you should be able to get the drivers off of canons website
Dec 03, 2009 | Canon ZR800 Mini DV Digital Camcorder
I can playback the tapes but now I can't see anything on the screen when I want to record. The screen is just black. Is something not set correctly?
If your camcorder is Canon ZR85 then it has bad ccd imager problem and that part will be replaced to see live view in camera mode for recording.
Canon offers Free of Cost repair for ZR85 model.
Click Canon CCD Imager Support for details.
Apr 07, 2009 | Canon ZR85 Mini DV Digital Camcorder
Image distorted in both modes canon zr85 camcorder
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced to back in business.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Good luck.
Dec 25, 2008 | Canon ZR85 Mini DV Digital Camcorder
Capturing analog video from 8MM tape and saving it on PC
Try Cyberlink Power Producer and set it do capture via DV cable.
Nov 30, 2008 | Canon ZR850 Mini DV Digital Camcorder
Canon ZR85
Feb 02, 2008 | Canon ZR85 Mini DV Digital Camcorder
Canon ZR85 Mini DV Digital Camcorder Logo
111 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
