Question about Insignia D300a PC Desktop
BIOS Good Morning, We are not sure who to ask for help. My hubby's pc is not very happy right now. He replaced the hard drive but it says he needs a BIOS password to get into setup. We have no idea what it is. We took the battery out but that did not seem to work. Any suggestions??? Thanks for your help.
    Genius:
  • 1,601 Answers
How long did you leave the battery out?
Maybe leave it out longer.
look for a jumper on the board to change to reset the bios.
Let me know how this works. Do not rate this yet.
thanks
Posted on Jun 14, 2008
Bootmgr is missing
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a
non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs
data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
Sep 10, 2012 | Acer TravelMate 8371 Timeline (LXTTD03077)...
When booting ask for pASSWORD
Is this a Bios Password, Hard Drive Password or Windows User Account Password? Did you set the password and forgot it? If it's a Bios Password you'll need to remove the CMOS Battery attached to the motherboard and let it sit a couple of hours then replace the battery and see if it forgot it had a bios password. Most times you'll have to disassemble your laptop to get to the CMOS battery. If it's the Hard Drive Password, them 99% of the time this is indicative of a stolen laptop and the only remedy is to try to give the laptop to it's rightful owner or replace the hard drive. Hard Drive passwords are enabled and can be done by the rightful owner remotely in some cases to keep thieves from getting to sensitive data. Maybe the guys at: http://www.generalsystemsconsulting.com can help you.
Mar 14, 2012 | Toshiba Satellite Pro S300-EZ1511 Notebook
How do you get rid of data on the external hard drive.
Go to My Computer, right click the external drive, cilck open. That will show the contents of the drive. Once you are happy that you wish to delete all the files click Edit/select all right click delete.
Or right click on the drive and select format.
Apr 09, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Not seeing SATA drive in bios
Try this, it might be this simple. Go into your bios settings and look for your hard drive setup and check to see if the ide connection is set to primary. If it is then change it to auto. Check the rest of the hard drive settings and make sure that all the hard drive settings are on auto, then check and make sure that you have connected the sata drive right and that the power connection is good, last step make sure that your sata drive is installed on sata1, not sure why but on some computers this does make a difference. Hope this helps
Jan 14, 2010 | HP Pavilion a706n PC Desktop
Turned on and is asking for bios password
If you have the hard drive installed in a desktop, remove your CMOS battery for about 5 minutes. Replace and you should be good to go. You will need to reset the time and date on your pc.
Good Luck
C2Solutions
Aug 19, 2009 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
I ahve philips 11nb5800 need to replace the Hard drive how do I go about it
well open your PC case and be sure to deattach it from power, then screw out the hard drive by removing the screw drivers then deattach it you will deattaach two cables one is with the poera dn the other one , make sure the new hard disk is on the master section and attach it again and start ur computer then go to the bios menu and identify and intall it there
Aug 29, 2008 | Computers & Internet
Windows can't detect any hard drive
Hello.
Have you check if every thing is ok in the setup ?
If you have the documentation of your Hard drive, set the HDD
manually( cilinders, heads, etc), i don't know the difference between 4M and 3M models, but may be significant.
The battery wont have any effect in the BIOS, you should thanks god for that, because if you could erase what is in the BIOS you could say good bye to your PC.
In order to recognize many new devices the BIOS manufacturer make software updates you can download ( if available)from they website an install it ( i don't recommend you to do that unless you have no other option).
The battery is only for the CMOS, a memory that keeps your setup configuration when you turn off your PC.
- Most Probable cause of that problem and possible solution:
You hard drive must be partitioned and properly formated.
You will have to start you computer using a 3 1/2 floppy disk or bootable CD with MS-DOS.
Note: go to SETUP and set the right drive to boot from first( A: in case of floppy, CD in case of CD), save and exit
Make sure the disk have some commands you will need, FORMAT among them.
I suggest you look for totorials about partitioning a hard drive.
Is no big deal but you have to know what you are doing.
Create a partition using FDISK command and activate it
then format the drive.
Now it is ready to be recognized for Windows.
In the process of windows installation( only XP), right before it start it will ask if you wish to format de Drive, answer yes( the fast one) and choose NTFS( a more efficient Partition for windows XP.
I hope this help you.
Good luck
Jul 12, 2008 | EliteGroup ECS PT880Pro-A (1.0A) Via...
Hard drive stops booting
Hi, If your computer stops booting from the hard drive and is asking for a boot disk, then: 1. The motherboard/PC is no longer recognizing the hard disk; 1.1 Go to your CMOS/BIOS setup and manually detect the hard disk, save & exit. 2. The CMOS/BIOS is set to boot from other devices such as CD, FDD or USB but not from the HD. If after configuring the CMOS/BIOS and the hard disk is not recognized, then it is probably defective and therefore need to be replaced. If the hard disk is recognized but will not boot, then some files of your OS needed to boot are missing, corrupt or overwritten. You would need to re-install your OS and opt for a "repair". Hope this be of some help/idea. Post back how things stand or should you need additional information. good luck and kind regards.
Oct 01, 2007 | Fantom Drives EXT HD 80GB| MTT80 RTL Hard...
Insignia D300a PC Desktop Logo
77 people viewed this question
Top Insignia Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Carlos L. Burgos
Carlos L. Burgos
Martin Clarke
Martin Clarke
Are you an Insignia Computer and Internet Expert? Answer questions, earn points and help others
