Question about Tricity Bendix AW1400W Front Load Washer
Screw inbetween the drum and the outer shell
My tricty bendix AW 1053 W has a screw stuck between the drum and the outer drum shell
If you take the rubber empting tube off the bottom of the drum you can work the screw down to the bottom and out of the hole. ensure all electrics are un plugged obviously.
Posted on Sep 03, 2008
Kenmore Elite H3 washer's loud in spin cycle & smells burnt.Debris & plastic in well inside washer.Pushed aside rubber ring & saw lg. gap btwn. metal drum & surrounding plastic.Parts needing replace?
It sounds like the drum has broken from the rear mount. This will chew up the outer shell. This is a very labor extensive job. The parts are expensive also. You will probably need a new outer shell and inner drum.
May 29, 2015 | Kenmore Washing Machines
Sounds like something is stuck inbetween the drum and the outer part.Doesn't spin freely by hand.Can something get stuck like a penny or rock or something
anything at times can work its way into the area between the drum and outer edge of it,, Ive pulled everything from dog bones to socks that rolled around long enough to become lodged in this area,, if you have an inspection plate at the rear or bottom of this machine, remove it, and with the help of a mirror you should be able to look along the sides to see if anything is there ,
Jun 08, 2011 | Frigidaire FTF530FS Front Load Washer
When in the spin cycle there is a thumping noise ...it comes from between the drum and the outer shell . I removed the top and rotated the drum by hand..sounds like something is loose between the two...
If, by "outer shell", you mean the case of the machine: The drum is held into place by strong springs (usually three), How is the condition of the springs?
If, by "outer shell", you mean the drain pan, which surrounds the inside shell where your clothes go, then they should never move separately from one another, in fact, if they have not been united by the press, rust often unites them. There might be a foreign objet between them which did not make its way down the drain, but that should not be anything physically heavy. I have never seen any washing machine with functional components in the drain pan whose area is not large.
:o).
Jun 04, 2011 | Washing Machines
Tricity bendix aw 1001 w is not draining,pump and
If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
Apr 20, 2010 | Tricity Bendix AW1000W Front Load Washer
Tricity bedix spin query
First of all make sure you have selected the correct spin speed if there is more than one setting.
Check and make sure prog 4 is mot a delicate wash prog, as it will spin at a lower speed if this is the case.
If it has a filter, locate it and remove to clean.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Tricity Bendix AW1000W Front Load Washer
AKG Model C451 EB Microphone.
I drilled a tiny hole (.038") through the outer shell and the cartdrige where the body of the XLR connector is mounted and screwed a tiny screw into it from a pair of old glasses.
Sep 29, 2008 | AKG (WMS40DIV444US54) Microphone
Can't get the drum shaft from outer shell
Toddah email me at aliikoa-2000@msn.com, I am on the road, but do have the part number for the complete assembly already to put in, just to tired to walk out to the truck after 14 hours.
Sep 01, 2008 | Frigidaire GLTF1670A Front Load Washer
Tricity Bendix washing machine AW 1000 W
remove the rear panel 4 screws and you will see it on the lower of the drum.
Feb 09, 2008 | Tricity Bendix AW1000W Front Load Washer
Kenmore front loader
There's no easy way of getting something out of between the tubs without removing the rubber door seal from the tub. It's a pain in the rear to get it to go back on too, because of the retaining spring that holds it in place. Are you sure the screw is between the tubs and not stuck behind one of the was tub fins? Most small items like screws will eventually find their way into the drain line and get caught in the drain pump strainer. Since you can't see the screw, it may actually be trapped behind one of the fins. One way of knowing is to roll the inner basket with one hand and listen. If you hear something rattling around it's somewhere in or on the inner tub. The outer tub (or shell) does not move. You can also look through the inner tub holes with a flashlight while turning it slowly to see if you can see anything between the wash tub and shell. Usually, water and gravity will force anything lying in the tub shell into the drain line. Let me know if this helps you.
Jul 06, 2007 | Kenmore 43142 Front Load Washer
Tricity Bendix AW1400W Front Load Washer Logo
106 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
