Question about Dryers
Dryer only runs for 15 minutes and than shuts off and won't turn on. when it cools down it will start but only run for 15 minutes it is a kenmore gas 1109728110072811 thanks
  • 868 Answers
It has a bad Motor and requires a experienced repairman to install it.The longer you use this motor it eventually will just make a buzzzzz sound. Please rate this !
Posted on Jun 14, 2008
Dryer completely shuts off after about 15 minutes. Cannot turn the dryer back on for about an after
SORRY TO HAVE TO TELL YOU BUT Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
Kenmore Elite Electric Dryer - in recent days the dryer will not start but makes a buzzing noise. If the dryer starts it may tumble for 2-3 to three minutes and then shut down. When the unit shuts down...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 18, 2011 | Kenmore 74892 Gas Dryer
Our dryer starts up and runs for a while (15-25mins) then a sound develops and the dryers stops working. It appears that whenever it cools down it will run again. On start up sometimes a strange sound is...
You definitely have a motor issue starting to develop. The motor bearings will usually allow the motor to run initially, but start to get loud after they heat up and eventually bind causing the motor to stop. The motor has a thermal switch on the side that will shut the motor off if it gets too hot, and will re-set after about 15 or 20 minutes.
The motors for this style dryer (I can't look up the exact part as I need the complete model # off your machine's model tag) are usually about $140-$160.
If you would like to get the motor and install it yourself, let me know and I can provide you walk-through directions on replacement of the part.
Aug 18, 2010 | Kenmore 800 6983 Electric Dryer
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
Dryer runs for 15 minutes and stops
check the in-line limiters on the heating coil tube.
Jan 15, 2009 | Kenmore 62882 Electric Dryer
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Dryer shuts off after 10-15 minutes
The motor is overheating and shutting down, cooling down, overheating again. Motors are expensive and tricky to install. PLEASE rate my solution as solved if you feel I answered your question accurately.. Thanx
Oct 02, 2007 | Kenmore 62872 Electric Dryer
Dryers Logo
93 people viewed this question
Top Dryers Experts
