Question about Brother HL-5240 Laser Printer
How do i check the ink level of my toner cartridge<
Soulvisitor
  • 1113 Answers
SOURCE: Cartridge not detected
Change ink! It has a sensor that stops operation to ensure ink lines remain with ink in them
There should always be ink left in cartridge otherwise the printer would suck in air and air would turn in to bubbles in the ink line which become blank areas on your printing.
Posted on Feb 08, 2008
SOURCE: CLP300 Waste tank
Just found the troubleshooting manual for the printer and emptied out the waste tank. Seems to work fine now.
Posted on Aug 31, 2008
  • 8080 Answers
SOURCE: How to check ink level on brother MFC-9440CN?
Run the Brother Control Center. Click Device settings. Click where it says Inklevel.
A simpler way is Start-->All Programs-->Brother--> ...-->Status Monitor.
An icon will lodge itself on the tray (a printer). When icon is clicked on, the inklevels will show.
Hope it helps.
Posted on Sep 03, 2009
jaystreats
  • 49 Answers
SOURCE: After installing re-filled ink cartridges, both
hi there
ok it will show on it re-filled but new ones to will show it is fill up
Posted on Dec 22, 2009
kenners2k
  • 89 Answers
SOURCE: HP Photosmart C6180. I can't check ink level on my computer
Not all printers have this option, but i think this one should. you may need to download and install the software, you can do that from here: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=id〈=en&product=1153494
Try the HP Photosmart Full Feature Software and Drivers and the HP Printing Diagnostic Utility
give that a go. Hope this helps
Posted on Jan 21, 2010
How do I check ink levels on HP 7760 printer
Dear Jeannine,
Greeting!
Check estimated ink or toner levels for your printer to determine if you need to replace any cartridges.
NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement ink cartridge available to avoid possible printing delays. You do not need to replace ink cartridges until you are prompted to.
Many HP printers display ink and toner cartridge levels on the control panel. Look for an ink drop or cartridge icon or an Ink Levels menu to check the status of each cartridge.
Figure : Examples of ink and toner level icons and menu selections on various HP printer control panels
If your printer does not have an ink level icon or menu, continue with these steps to check ink or toner levels from your computer or mobile device.HP Customer Support - Software and Driver Downloads, enter your printer model, and then clickDownload next to the full feature driver or HP Easy Start to download and install the driver.
Jun 06, 2018 | HP Office Equipment & Supplies
CHECKING THE INK LEVEL
to check the toner level just press the button and wait the second light(orange) to turn On and then release the button. The printer will print two pages one with configuration and one with the supply status of the toner cartridge
Dec 26, 2015 | HP LaserJet 1300 Printer
Reset ink levels
For resetting the toner levels, cartridge memory chip has to be replaced. Memory chip was mounted beside of the each cartridge & its easy available in the local market.. For better idea pl see the snap..
Jun 16, 2013 | HP LaserJet 4600 Printer
How can tell if the ink level is low? hp 2420
Cartridge comes along with memory, the information of estimated ink/toner levels will stored in this memory(Depends upon the cartridge model yield will varies). When printer performs the printing, memory count will comes down, when its reaches the minimum count printer will display the message of "low ink/toner/remain pages" levels, once its reaches to '0', display will changes like "replace the cartridge"...But there is no electronic component or mechanism to measure the ink/toner levels in the cartridges.Only estimated levels only printer can recognizes.. Take usage page through menu, you will get the information that usage % & printed pages info,you can judge how much remain it can print...
Dec 06, 2011 | HP LaserJet 2420 Printer
How to Check the ink level in cannon lbp 2900
The Canon Laser Shot LBP2900, does not use ink(liquid), it uses a Cartridge called "Toner" which contain "black powder" form in the cartridge capsule.
If you wish to check the Toner Level, refer to this guide @ http://support-in.canon-asia.com/contents/IN/EN/8100134600.html
Hope it helps.
Jun 15, 2011 | Canon LASER SHOT LBP-2900 Printer
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Hp photosmart c7250 ink system failure
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 03, 2010 | HP Photosmart C7250 All-In-One Thermal...
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
Refilled cartridge still says 0% ink
hit <> together then 789 to disable ink levels
Jun 24, 2009 | HP OfficeJet d145 InkJet Printer
Brother HL-5240 Laser Printer Logo
106 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
