Question about Epson Stylus CX4800 All-In-One InkJet Printer
Printer reboots computer
My problem is the following: my printer will print the first document just fine. However, the second document will take at least 15 minutes to print?
Also when I shut the printer, my computer will reboot automatically. Then when the computer reboots it gives me the error message to check drivers.
I am running Windows XP
Hoping someone can help?
Ron.
  • 197 Answers
Yeppers..
remove the existing software for printer
go to www.epson.com and get fresh drivers
install them
try it again
Posted on Jun 16, 2008
Printer keeps saying busy printing another document
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 10, 2012 | Lexmark X4580 InkJet Printer
My printer will not print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aNGYmW. Select your operating system, download and execute the file. After the install process, try to print a document again to verify that the problem is fixed.
Oct 23, 2011 | Lexmark X2600 InkJet Printer
Cannot Scan Document into my computer after doing the following: click scan; click download to computer; clicked OK; receive message Downloading Application; then receive message cannot retrieve...
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 24, 2011 | Lexmark X4690 Wireless InkJet Printer
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
4. Reboot your pc.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
HP B8850 photo printer originally installed on an XP machine. Now running on a Win 7 unit (SP1) x64. Most printing done from Photoshop CS2. Up until a few months ago, everything ran fine on the x64 Win 7...
Try this.
Right click on the desktop and create a new Text Document, rename it spooler.bat
Be sure your computer is set to display file extensions otherwise you will end up with a file called spooler.bat.txt but the .txt will not be displayed. Right click on the file and select edit. type the following:
net stop spooler
net start spooler
Save the file.
Between print jobs, run this by right clicking on the file and Run as Administrator. Maybe restarting the spooler will work and you will not have to reboot.
Mar 07, 2017 | HP Photosmart Pro B8850 Printer
Wontprinto or scan from computer
1.check the printer set up in the Windows print screen
2. clear all document from the print queue in the PC.
3. unplug the printer for about 30 seconds then plug it back into the AC.
4. Reboot the PC
5. try printing your document again.
Apr 06, 2010 | Office Equipment & Supplies
I cannot connect the hp psc 2175 to my computer
Check your usb cable works fine.
check your computer usb ports are works fine.
Try with usb prots 1 by 1.
Also uninstall driver then reinstall.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | HP PSC 2175 All-In-One InkJet Printer
I have z645 printer
I need Laxmark Z645 Printer Driver & Software
Mar 29, 2008 | Lexmark Z640 InkJet Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
55 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
