Question about Lexmark Office Equipment & Supplies
I have a Lexmark P6250 and when I scan a photograph that is the size of the scanner glass I get a white band along the bottom!Smaller pics ok as I have been moving to the back of the glass to scan.No light entering!
  • 197 Answers
Usually this scan image area is adjustable with doing a preview..try to make sure it's not 'bleeding' at that stage.
Posted on Jun 16, 2008
I need to get a scanned photo from scanner to computer how?
What i usually do is open a new microsoft office publisher 2007 document, in the picture format toolbar click on the scanner icon ,should say insert picture from camera or scanner. That should take care of ur problem. Then right click on the picture once its scanned and select save as picture and rename and store ur pic
Nov 01, 2011 | Lexmark P6250 All-In-One InkJet Photo...
Trying to copy a letter size document. Print on right side of document starts fading at about 2" from right side of paper edge
Check the scanner glass for dirt, or debris from previous scans. Smoke on mirrors, dust all contribute. Dont use canned air.
Nov 18, 2010 | Lexmark P6250 All-In-One InkJet Photo...
Use of Scanner
On this model there is a SCAN in black and white or color buttons but you need to have something on the glass to scan. Once it scans it prints!!!
Now lexmark software if installed comes with a program to scan with. you need to check under your prgrams folder under lexmark for the scanning software that was installed with the print driver.
If you open the lid and you do not see the white light chances are your scanner has and needs a bulb inside and at the point to install one of these you might want to concider a new printer.
Please be considerate and leave your feedback and comments and ratings before you leave, Thanks
Apr 30, 2010 | Lexmark X2500 All-In-One Printer
Getting a black strip in copy mode on X6575 lexmark printer. No line in print or test mode
Most likely a page was scanned with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | Lexmark X6100 Flatbed Scanner
How do you scan a picture into the computer with a lexmark P6250?
SORRY, I COULD DO ALL, SAID TOO BIG, Using a computer 1. Make sure your All-In-One is connected to a computer.
2. Load your document face down on the scanner glass. For help, see Loading your document on the scanner glass.
Open the Lexmark Imaging Studio. For help, see Using the Lexmark Imaging Studio
4. Click the Scan button.
The All-In-One Center appears with the Scanning & Copying tab expanded
5. Click Preview Now in the upper right corner of the All-In-One Center.
An image of the scanned item appears in the preview section.
6. Click and drag the dotted line box to select a specific area of the preview image to scan.
7. Click Display Advanced Scan Settings to review and change the scan settings. Click OK.
here is the web site where the info was. If you want to see better images just click on link below. good luck :0)
MORE LOOK AT WEB SAYS TOO LONG
http://www.lexmark.com/publications/
pdfs/2007/6200/winug/en/frameset.html
Nov 19, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Scanning 35mm negs on my Epson Stylus PHOTO RX620
Try using a slightly off-white background sheet behind the negative (glass-negative-sheet-scanner lid) first, or a "frame" around the negative that is anything but white... some scanners have an auto-detect feature that may be skewed for one reason or another.
Another trick, from a photographer friend, is to take saran wrap or another transparent but non-reflective material and place as a filter between the negative and glass, thus reducing glare. The sharpness may be lessened, but the glare is also lessened...
Hope this helps!
-- RT
Aug 28, 2009 | Epson Perfection 4490 Office Flatbed...
Lexmark P6250 won't scan in Vista64
Disconnect the printer or at least be sure it is turned
off. I'd do both and reinstall the CD software program
that came with the printer.
When the software program asks you to
connect the printer to the USB port, do so and it
should again work properly.
Hope this is of some help. Bud
Jul 12, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
PDF Files When Scanning with X4270
If you can reduce your scan resolution (e.g. 150 DPI instead of 300 DPI) or color depth (scan in black and white instead of color) it will result in a smaller PDF.
Steve
Feb 25, 2009 | Lexmark X4270 All-in-One Multifunction...
Scanner Creates a Very LARGE PDF file 1.8 meg for one page
I have an old X7170 and have the same problem when using the doc feeder. I scan using the flatbed the size is much much smaller.
May 05, 2008 | Lexmark X83 All-In-One InkJet Printer
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
