Question about Sony KP-65WV700 65" Rear Projection HDTV
Red my tv turns red after about 30 minutes My Sony T.V. kp-65wv700 after a 5min the screen turns red. If i shut the tv off and on the screen is good for a 3min. When the screen has a dark background (black/blue) the red is deeper and the picture fades.I beleive the tubes (red/blue) are bruned out or worn. Sometimes when changing channels the previous image stays on the screen for short time.
    Novelist:
  • 97 Answers
Het Big AOT-
Sounds like the screen drivers for the blue and green projection CRTs sre possibly going south, or it could possibly be the CRTs(picture tubes) themselves going bad, although it would be highly unlikely for two tubes to go south at the same time. My money would be on the control circuits (screen drivers).
The easiest way to troubleshoot this problem would be to obtain a can of circuit cooler from an electronics supply house and determine the area on the motherboard where the screen drivers reside; then turn on the set and let it heat up until the problem occurs, and then carefully spray (one at a time) the components in the screen drivers area. When you hit the faulty component (probably a chip), the problem should clear --- until that part heats up to failure point again.
Determine the part #, obtain a replacement part, replace it and hopefuly the problem will be solved.
The last time I encountered a similar problem in the real world, it turned out to be a cracked circuit board, and all of the intermittently broken circuit lands had to be bridged by resoldering over the cracked area... a tedious and time consuming process.
If the set is still covered under warranty, let Sony fix it... any attempts by you could void the warranty!
Hope this helps and good luck! Keep us posted as to your results...
-WB
Posted on Jun 14, 2008
My Sony big screen rear projection TV model KP=51HW40 produced 2002 screen flashes red then shuts off. We can turn it back on and it will run for 30-60 minutes and then it repeats red flash. Is this
The Problem you are having is a Cathode to Grid Short in the Red CRT,When it Shorts the screen will Go all Bright Red and shut Down,The Best fix Would Be to Replace the Defective CRT (GUN)
Dec 30, 2011 | Sony Televison & Video
The screen turns blue after about 2 minutes of turning on the TV
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 25, 2010 | Sony KP-57HW40 57" Rear Projection...
Screen turns red then shuts off
Sounds like a bad red projection tube, disconnect red tube socket and try again if tv stays on reconnect tube soket and adjust screen controls on front of tv under the front panel which you will have to remove to do any of this. There are six adjustment controls 3 are for focus for each color and 3 screen controls for each color. Look close at the black plastic control module should be labled R G B for focus and R G B for screens. Good Luck!
Mike
Apr 14, 2010 | Sony KP-51WS500 51" Rear Projection...
My screen fades to red, then the TV shuts off
It is your red picture tube that is your problem . This is common with Sony projection TV's of your age . You will need to replace the picture tube . If your going to do this yourself you should have some knowledge of replacing a picture tube as you need to align the yoke and purity rings and adjust the settings of the red tube. If not call around to some local shops not the big box stores to get the best price on labor and parts . Depending on the price of the tube expect anywhere between $350.00 to $500.00 to get fixed . There might be a remote chance of a loose connection on the red circuit board and this should drop the repair price $175.00 depending on there labor charge . Make sure your colors were very good before you had this problem. If not all three need to be replaced and this would be costly and cheaper to buy a new TV. So if a shop tells you to replace all three this is only done if your colors were weak and the picture was not as bright and clear . Good luck , Team tech
Jun 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Tv will not stay on only for 1 min. then turns red and off
Symptoms shows Red Tube is defective and needs replacement.
Please confirm model number with serial to look for Red Tube in stores.
Thank you.
Dec 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Kp-57ws500
My tv too had a blue screen problem. Then it started to shut down after staying on for less than a minute. I thought that I would with a huge repair bill but I followed the directions at this link: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html and now my tv works perfectly.
May 01, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony turns on and off again
Apr 27, 2008 | Sony KP-57WS500 57" Rear Projection...
Red Screen
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
Sep 24, 2006 | Sony KP-57HW40 57" Rear Projection...
Sony KP-65WV700 65" Rear Projection HDTV Logo
120 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
