Question about Lincoln ELECTRIC K1756-1 PRO-CUT 25 PLASMA CUTTER
Arcs for a couple of seconds and goes out. Does this every time trigger is activated. Has new consumables. No fault lights appear.
My trigger switch works sometimes and then other times the trigger switch doesn't work and my light goes dead. Do I need to replace the switch and if so can you buy them.
Either the switch is bad or the wires going to/from the switch are loose and making intermittent contact. You need to open it up to see whats happening.
Feb 27, 2015 | Channellock Channel Lock 4v Dual Driver
I have audi A6 2.4 model 2006. When I start the car in morning, the battery sign appears after a couple of seconds. But when I accelerate a bit it goes away. The normal position of the rpm should be about...
Afraid not. Although the light goes out it still may not be charging very little charge will put the light out. the other reason I feel it's the alternator is instead of rpm increasing it should decrease as a properly charging alternator should pull the engine which should decrease the rpm
Aug 10, 2014 | Cars & Trucks
Eninge lite blinks fast and wont start
Pull any error codes.
The engine light lights up when you turn the ignition switch on, then goes off. After four seconds, if it comes on again and stays on, there is a present fault code. When it is an historical fault code, it comes on with ignition and goes off then comes on and goes off again. I believe in like 4 second intervals. A historical code will not be removed until a cycle of 50 ignition on/of intervals has passed. In other words, the engine light will continue to light two times when ignition switch is turned on, after 50 on/off cycles have passed the historical codes will no longer affect the engine light when starting.
If you will hold the odometer button on the side of the console down, and turn the ignition on and off, three times I think, waiting for the fuel pump to stop before turning the ignition switch to the off position, and one second until you turn it on again, the third time holding the odometer button down until the engine light begins to blink it will begin to blink in a fast sequence showing the fault codes will follow.
First indication of fault code display is rapidly blinking engine light. After that count the number of times the engine light lights up. There will be a brief pause between digits. If there are multiple codes stored, the rapid blinking will separate each. Once the fault codes begin to repeat, you have gone through all stored codes.
Tips: Have a pencil and paper ready.
Maybe ask a friend to help out. Sometimes a second pair of eyes can be good.
Go through a couple of cycles, so that you are sure you haven't missed any codes.
One example is if it blinks 3 times, pause, the blinks 2 times, that means 32.
Code 32: Rear Fuel Injector
Feb 16, 2014 | 2000 Harley Davidson FLHTCUI Electra Glide...
Interior lights do not go off when you close the doors
Diagnosed it for him as the lock cylinder not being straight.
With keyless entry and alarm systems, the key locks (and the transmitters) use ground triggers for a couple of things.
First of all, a ground trigger is used to disarm the VATS. I think most of us know that.
Second of all, a ground trigger is used to wake-up the light-timer board. When you open a door, the door jam swithes provide that same trigger. And, as long as the ground stays active/connected, the lights will stay on. Only AFTER the ground drops will the timer cause the lights to turn-off after 30 seconds.
I have to say it would be tough to catch/diagnose the door lock causing the issue by being skewed, but I can see it happening.
Jun 04, 2013 | 1994 Chevrolet Corvette
Screen goes black every second
default your power saving settings,choose when to time out your screen
Mar 31, 2013 | Fujitsu AMILO PC Laptops
Defective KitchenAid microwaves causing dangers to lives
That is extremely dangerous, from your decription something went wrong with the keypad control board and possibily one of the door switches malfunctioned and the fact the magnetron was arcing did not trigger the fail safe systems indicates a design flaw in the system. I would demand a brand new microwave with a model that has a great safety record.
Jun 12, 2012 | KitchenAid Microwave Ovens
WHY DOES THE ENGINE CHECK LIGHT GOES ON AND OFF STAY ON OFF IN A CHRYSLER TOURING 2007
Your vehicle's OBD computer monitors all your vehicle's electrical emission circuits.
Each time you turn your key, the computer considers this 1 x drive cycle.
When a fault (or out of spec) condition occurs, this will register a fault code in the computer's memory. Some circuits will only trigger the Check Engine Light (CEL) after the same fault occurs a few times. Other circuits will trigger the CEL with just one fault detection.
In the same manner, if the fault condition is only intermittent, the computer may consider the condition recitified, if that fault does not occur after several drive cycles (i.e. the CEL will no longer light up).
The only way to have this resolved is to arrange for your local Mercedes dealership (or authorised service agent) to connect their factory SCAN TOOL.....and read your computer's stored fault codes.
These fault codes will quickly identify the suspected circuits (eliminating unnecessary garage labor costs), allowing quick diagnosis & repair.
Note: Mercedes Scan Tools operate on a different communication protocol. Typical scan tools designed for American & Japanese vehicles use a different protocol, therefore, I recommend this be done only by a Mercedes agent (or European service specialist).
The process of scanning for fault codes only takes 15-25mins (depending on the technician's experience), hence should not cost you much to have this procedure performed.
"Please take a moment to rate this solution with a 'testimonial' and/or 'thumbs up', as this will keep my status active and allow me to continue offering technical support. Thank you."
Jul 31, 2011 | 2005 Chrysler 300
Alarm not beeping when doors are open. led on door goes red when door is opened and alarm box has red and green lights when alarm is actived but not chimes or alarm when doors are opened
When a zone has both red and green lights on, it means that it is in delay mode. That means when the sensor is triggered, the system will wait for a predefined time interval (30 seconds) for user to reset the trigger. During this time interval, the system will not beep or alarm. But after that, if user does not reset the trigger, system will go off.
User can reset the trigger from keypad or by remote.
Sep 05, 2010 | Skylink Group Skylink Security System Kit
W810i
i think you changed you handset s light settings...
so change it to automatic so the light active during the call will be handled automatically.......
once you change that light settings to automatic then phone will control the light settings so that when you are active on call for some seconds the backlight will be active after that it will get off automatically...
Feb 12, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Screen color messed up, won't connect correct
well can you come into recovery mode? hold(activated) push rec button and hold it while start your mp4 if it works get me information about it..
Feb 01, 2008 | SanDisk Sansa e250 MP3 Player
Lincoln ELECTRIC K1756-1 PRO-CUT 25 PLASMA CUTTER Logo
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
