Question about Konica Minolta DiMAGE G500 Digital Camera
I bought a Kingston 4GB Class 6 SDHC Card for this camera, and when I put it in the camera, it doesn't seem to be recognized by the camera.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Konica Minolta Master
  • 102,366 Answers
The G500 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Posted on Nov 05, 2010
4gb kingston canon ixus 50
The IXUS 50 works with MMC and SD cards. Your new 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Jun 04, 2012 | Canon PowerShot SD400 / IXUS 50 Digital...
Got s205 coolpix and experiencing problem whnever i put in the SD card.. it always says. card cannot be read.. card that im using is a new one and it is 4gb.. dunno if the problem is in the cam or the...
Actually a 4GB SDHC card should be compatible with an S205, as that camera is new enough to work with SDHC. One thing to try before going through the below linked troubleshooting tips is if you have another card, try it in the camera. If the camera recognizes it, then it's likely that the card you purchased was defective, thus you should return it.
For others reading with similar problems, there are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 26, 2011 | Nikon Cameras
Kodak Z740, want to know if the 4GB SDHC card Class 2 will work in the camera...I've tried a 4GB SDHC Class 10 and it won't format, but would a Class 2 work instead?.
Class 10 just means it will read and write information much faster than a class 2 card. The real issue may be that your camera can't use SDHC cards. Check your manual to see if it will only accept SD cards.
Nov 15, 2010 | Kodak EasyShare Z740 Digital Camera
I have bought a 4 Gig SD card but my camera won't accept it
If it's a 4 GB card there is a chance your camera doesn't have SDHC support.
SD cards 4 GB and over are called SDHC cards and your phone may not have the ability to "talk" to the card.
Jul 09, 2010 | Kingston 4GB Secure Digital High Capacity...
Drivers for detecting 4gb kingston SDHC
SD vs SDHC is a question I get alot. First let me explain your issue. Unless your CARD READER is rated for SDHC chances are its an older model and cant handle the card, even with driver updates. You will need to check the manufacturers website of the device you are using as a reader to see if there are newer drivers. If its a laptop go to the manufacturers page and and be sure and choose Windows XP as your OS. Ok, now to the difference. SD cards are called solid state memory. The internal workings of each hasnt changed much except that the SD card used standard file formatting that was understandable in Windows XP and earlier operating systems. the SDHC (HC stands for High Capacity) uses the same architecture in teh card but changes the way data is stored and read that enables it to hold more data on same size device. (note architecture means design of card type not inside guts) Thus your system and Operating system may not be capable of addressing the new coding and file system changes on teh SDHC cards. Many older cameras (2008 and before) dont recognize SDHC cards either. Good news is they make an SD card (plain) in a 4 gig and you may be able to replace yours at the retailer with teh correct one needed (unless you bought via ebay or other method) Yours is a good question and is often asked, so dont feel bad in anyway. Just look at it this way.. you learned the lesson recently when the pricing between the two is about the same.. I learned the lesson 2 years ago when an SDHC cost about 80$ compared to 19 $ for a normal SD... SMILE!
Jun 28, 2010 | Kingston 4GB Secure Digital High Capacity...
Nikon Coolpix 5900/4 GB Kingston SD Card
The 5900 uses SD cards. The 4GB card you have is actually an SDHC card and will not work in the 5900. You'll have to stay with cards 2GB and smaller.
May 19, 2010 | Nikon Coolpix S210 Digital Camera
Canon Legria HF200 SDHC Initialization problem
This totally sucks. I have a similar issue with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When trying to initialize the card, its fails and says "Process terminated with error." It also says "check the memory card" when I first put it in. Write-protect is off. My other SanDisk class 4 SDHC card seems to work ok.
I could have sworn it worked before and I was able to transfer videos to my Mac on 10.6, but I can't remember for sure if I was using the SDXC card or just the built-in memory. Very frustrating.
Apr 12, 2010 | Canon Legria HF200 Flash Media Camcorder
Will a Kingston 4 GB HC card work in this camera?
I just put a Scan Disk 4GB HC card in my D40 last night. The card said it would only work in devices made for HC. It seems to work fine.
Dec 05, 2008 | Moultrie GameSpy 4.0 Digital Camera Deluxe
SDHC memory card compatability with 7600
no, will not take SDHC.
SD only sorry
Regards
Richard.
Jun 30, 2008 | Nikon Coolpix 7600 Digital Camera
Konica Minolta DiMAGE G500 Digital Camera Logo
128 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
