Question about Iomega (33654) Limited Edition 500 GB USB Hard Drive
My laptop crashed while the external drive was hooked up by usb. Had to shut both down. Now the hard drive will not show up on any computer as it did before and cannot be opened to be viewed. I need the files on it to be accessible.
    Brigadier General:
  • 10,406 Answers
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 05, 2010
I have a WD 500Gb My Book that doesn't allow access to information. My laptop crashed so I reformatted it and reloaded it. The My Book holding all my backed up information shows up as connected as a...
the computer for some reason is not fully detecting the ext drive if its usb then try other usb connections. if it has sata hook up try using that there a much better connection but dont worry i think youl find that all your information is still on the ext drive thats why we should all use external drives for all our important photos music and files because when the pc blows or crashes then the other drive is not affected
p.s if the ext drive can with a driver disc try reinstalling it.
good luck
Jul 12, 2010 | Western Digital My Book Premium ES...
My computer does not read my external drive (WD MyBook 250 GB). My work computer will not recognize either. It was working fine, but a Firefox crash necessitated a computer restart. After the restart, the...
You don't say which version of Operating system you are using. My thoughts are to first go to "my computer" and see if your drive shows up there. If not, get to disk management and see if it shows up there. The crash possibly could have messed up your external drive, and now it needs to be initialized and/or formatted.
Nov 05, 2017 | Western Digital 250GB MyBook External USB...
SimpleTech 250GB External Hard Drive can't be recognized
First of all,
uncheck the "Allow the computer to turn off this device to save power" option in the device manager for USB Hub Properties, Power Management Tab.
Try rebooting the computer once as C:\Windows\inf\INFCACHE.1 file may be corrupted and need to be replaced (either restore a previous version or just delete it and try connecting again).
Next,completely uninstall all USB devices and the main hub and then re-install.
Sep 07, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Laptop does not recognize my Drive Station, External USB 2.0 Hard Drive, maker: Buffalo worked fine for months now nothing.
I will help you diagnose.
Lets check the easy stuff first.
1. First- Just switch to a different usb port.
Try?
2. Try using a different cable.
Try?
3. go to my computer, properties, hardware, devices, scroll down- delete usbs-
unplug your harddrive from your computer -after having turned it off of course.
leave off for eight seconds
Plug hard drive back in
Try?
4. Try restore computer to a time the Hard Drive Worked?
Try?
Diagnosis Crashed Drive
Mar 26, 2009 | Computers & Internet
Can't Find Hard Drive.
Go into the notebooks bios and see if there is a boot from USB in the boot sequence section. If there is, then enable it. If there is none, then it will never boot from an external drive.
Jun 09, 2017 | Hitachi Travelstar 80 GB Hard Drive
Computer Doesn't See Freeagent Go 250 external drive
Uninstall all usb controllers from device manager and then restart your computer. Scan ur system with mcafee 8.5i
Jan 29, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Hard drive crash
Possibly. It depends on the crash. If the drive won't spin at all, then there is one way, but it will have to be sent off and it's expensive. If the drive still seemingly works (spins and tries to read), then it has a bad sector and some of the info, that is not effected by the bad sector can be retrieved. You can do this yourself by purchasing an IDE to USB, or SATA to USB hard drive connection cable, depending on the type of hard drive that's in your machine. Sometimes you can find them at Bestbuy for around $15, make sure it's for laptop and not desktop. This cable allows you to hook any laptop IDE /SATA hard drive to your machine as an external and read it or use it for extra or backup storage.
Jul 07, 2008 | Dell Inspiron 8600 Notebook
Nexstar IDE to USB, Will Not Show Up
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Apr 06, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Iomega 160 gb External
Since this is an external drive, I assume you can try connecting it to a different computer? Does is it still crash if you do that?
Nov 08, 2007 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Iomega (33654) Limited Edition 500 GB USB Hard Drive Logo
91 people viewed this question
Top Iomega Computers & Internet Experts
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
 Grubhead
Grubhead
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
