Question about Nokia 6350 Cell Phone
Brand new Nokia 6350. Two weeks old. Battery does not charge or the phone does not come one despite leaving the charger on for several hours. I got a new battery sent from ATT. The phone still wont come on. I put the charger on with the new battery, Still does not come on. I guess the phone device is bad.
    Top Expert:
  • Nokia Master
  • 53,745 Answers
Send it back for a warranty refund
Posted on Jan 05, 2018
SOURCE:
  • 67 Answers
SOURCE: Nokia 3250 charging problem
you must change the charging block /base pluck or go to the service provider will do it for you. advice by dogy.
Posted on Dec 21, 2007
270rexton
  • 782 Answers
SOURCE: nokia 5800 wont charge?
Use different charger. When charging leave the phone off. Fully charged after 4 hours.
Posted on Jun 10, 2009
  • 3 Answers
SOURCE: Nokia 3600 not charging (it says "charger not supported")
I had the exact same problem. There is something wrong with the new charger, either the voltage or something... But when i changed to the old Nokia chager (same small pin) It worked. One can prob just deliver it back and get a new charger.
Posted on Jul 11, 2009
longgee
  • 322 Answers
SOURCE: NOKIA 6300 WONT CHARGE
Sir, the problem lies in the connector (it is where you plug the charger). It is not functioning anymore. Try replacing that. But before anything else, i suggest that you have the phone reformatted first. Sometimes, this can solve any problem. To do that, turn the power off. then press and hold this in this sequence: green/talk + 3 + *, then press the power on. release the buttons when you see the reformat starting.
Posted on Jul 19, 2009
SOURCE: problem with charging nokia 5800
buy new mobile .........
Posted on Feb 28, 2010
I have a nokia 6350 and the charging port tore up so i cannot charge it so i can get my stuff off it and put it on my new one
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 24, 2012 | Nokia 6350 Cell Phone
Sonim xpi jcb toughphone,the phone won't switch on,but when the battery is removed and replaced the phone comes on.However none of the buttons pressed gets a response,can,t enter pin and it won,t turn...
Remove battery,attach and switch on charger,for about 10mins or until charge mode displays,should flash.Insert battery, donot disconnect charger,leave for 2 hours,disconnect charger ,phone should switch on.
Jan 24, 2010 | Sendo Sonim XP1 JCB phone extreme...
My Nokia E71 won't turn on
Take out the battery and unplug the charger AFTER charging it for 2 hours to ensure full battery. Now leave your phone for without the battery nor the charger for 5 minutes. Then, re-insert your battery only and the cover.
Turn it on and wait for around 5-15 minutes then it will go to the standby (the part where you dial your numbers).
Hope this Helped!
Oct 12, 2009 | Nokia E71 Smartphone
I can't connect my mobile with any computer , it says mobile has failed to pass in widows logo test
My Nokia 6085 which I bought two years ago recently started by failing to charge fully despite change of chargers and change of baterries. Today the 6085 completely quit and no light on the screen despite use trial with brand new fully charged battery.\r\nHOW CAN I RECOVER MY DATA I HAD SAVED IN THE PHONE`S MEMMORY SO THAT I CAN MOVE ON
Aug 23, 2009 | LG Cell Phones
Nokia 5800 wont charge?
Jun 10, 2009 | Nokia 5800 XpressMusic Smartphone
Sidekick 3 battery problems :(
what you do is get a new battery and if that does not help the situation then take the phone into a service center to have it check.
Jun 17, 2008 | T-Mobile Sidekick® 3 Cellular Phone
It won't turn on...
you may have been sold a duff battery.you could try replacing with a new one.a bit of a bummer but it does sound like the battery is dead.hope that helps.
Mar 04, 2008 | Nokia 7390 Cellular Phone
Battery Charging
If both the charger and the battery are warm to the touch, the battery is probably charged.
The low battery level warning level is learned by the phone. To train it, allow the battery to run down once until the phone stops working, then recharge it.
The best way totest the charging operation would be to try using the phone. Fully charged you should get about 6 hours of talk time from a fully charged battery, and at least a week of standby operation.
Dec 25, 2007 | Motorola Mobility V176 Cellular Phone
New Nokia 2660 phone battery dead
does the battery bar go up and down like it is charging or is nothing happening if nothing happening then it is probably your charger has packed up it might be a split wire inside the cable try another charger or take it to a phone shop and they will try it for you for free and they can tell you if its your charger hte battery or the phone if the phone hasnt got wet then it probably is the charger u can get these cheap and a phone shop might have some second hand ones this should solve your problem hope this is some help
Oct 28, 2007 | Lands Phones
Nokia 6350 Cell Phone Logo
189 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Damen Wong
Damen Wong
