Question about Jenn-Air PRG3010 (NP) Gas Kitchen Range
Install a down draft range (replace)
Were can I find instructions on how to install a down draft range? My mother-in-law is to cheap to have it installed by a pro.
What product can I use to replace a down draft venting system from a Jenair range when I have to install a range hood above a new range and wish to vent down and out of my house in the same place of the...
Short answer is if you have the vents already in there is a product to make use of these. I would recommend talking to an appliance dealer for your options on this one. I am sure they would steer you in the right direction.
Mar 01, 2015 | Range Kleen For Whirlpool Jenair Ranges
Jenn air s166w down draft range with ill-fitting grease filter when we moved in. I think the range is 20+ years old. The replacement part I ordered is too wide (6 3/4 inch) for the opening of 4.5 inches...
i have had trouble with this filter in the past, it seems they changed the body style years ago and the filter you have is for the new down draft
but your problem is not that hard,
you can buy the proper air filter at you local hardware store and make your own replacements for pennis on the dollar,
one 3.00 filte will get you between 3-9 filters
you want a charcoal filter you can just lay it in under the air grate
Oct 08, 2009 | Kitchen Ranges
Hotpoint RVM1535DMCC OTR micro-has NO stove top draft.
Did you check the installation instructions and the owner's manual?
You can download GE owner's manuals and installation instructions
here.
If you still have a probme, I would call the GE Answer Center:
GE Answer Center®
1-800-626-2005
Monday - Friday: 8 a.m. - 10 p.m. ET
Saturday: 8 a.m. - 7 p.m. ET
Closed Sunday.
Mar 05, 2009 | GE Hotpoint Over-the-Range Microwave
Instruction manual
Try this it might not be yours but it is a manual. If I get the model # I can get you the right manual.
http://www.ajmadison.com/ajmadison/itemdocs/Dispatcher_REQUEST=ITEMID&itemid=49-80216.pdf
Good Luck and Please Rate FixYa!
Feb 27, 2009 | GE Profile JVB98SHSS Kitchen Hood
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Replacing Jenn-air down draft with new unit
Since Jenn-Air has been acquired by Whirlpool, there have been an explosion of problems with their appliances.
Please research your intended purchase before deciding on a replacement:
Jenn-Air info
Considering the array of early failures everyone seems to be having with appliances (US made and foreign) bought in the last few years, I couldn't even recommend a manufacturer any more.
Jan 25, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Jennair down draft cooktop
hi i have a Jenn air down draft as well you should have a spring loaded flap like a dryer they sell them
separately, you can buy them at home depot or lowes that will stop some of the cold air coming in not all of it.
Dec 14, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
User/instruction manual
try here under down loads http://miele.com/
Dec 31, 2007 | Ovens
Installation of down-draft exhaust duct for Jenn-Aire cook top
We're buying a JES9900BAF for an island and found ducting instructions in the installation guide. Go to jennair.com and find the page for your range model. Then click on the "Specs/Literature" tab (it's about 2/3 down the page). The installation guide is a PDF document.
Nov 07, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Can you give me easy install directions?
are yours and hers both freestanding? (do they both have a drawer at the bottom?) if so measure the width to see if hers will fit. if so, turn off the circuit breaker to your stove. remove the drawer of your stove. do you see the plug? unplug it. now just slide it out toward you being careful not to damage the floor. installation opposite of removal.
Hope this helps
Oct 31, 2007 | Frigidaire FGF337EC Stainless Steel Gas...
Jenn-Air PRG3010 (NP) Gas Kitchen Range Logo
378 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
