Question about Toshiba Computers & Internet
C0000218 error message - need to start from XP Pro disk in CD drive
    Genius:
  • 1,601 Answers
This may help you. Do not rate this yet. Let me know.
thanks
http://www.jakeludington.com/ask_jake/20050821_stop_c0000218_registry_file_failure.html
Posted on Jun 14, 2008
How do you fix error c0000218
microsoft have stopped supporting windows xp some time ago
best to delete from the computer and buy and install windows 7
I have been told that you can't have 2 operating systems running on the same hard drive and this may be causing the conflict
May 23, 2015 | Dell Computers & Internet
Stop c0000218
Which operating system ????
If you've just installed Windows XP on your desktop and you've received the following error "STOP: c0000218 {Registry File Failure" you're not alone.
This is a known issue with XP that can arise from incompatible hardware being installed with XP or, in the worst-case scenario, from a faulty hard disk.
Luckily, it is fairly simple to figure out if your disk needs to be replaced or if a software fix is enough to solve the problem.
Check if your hardware is compatible with Windows XP.
You can find compatibility information at the official Microsoft marketplace website (see Below).
http://www.windowsmarketplace.com/
Use the recovery system if your hardware is compatible but is still not working. You can access the recovery console by simply putting in your Windows XP CD before booting your computer.
You will be asked whether you want to "Repair or Recover.
" Simply press the "R" key.
Type in your administrator password.
(You must have admin access to use this option.)
Choose to use the "chkdsk" command line, which will allow you to check your disk.
Once in the chkdsk use the "chkdsk /r" command to check your hard disks for errors.
Press "Enter" to start the disk check.
Type in "chkdsk /f". If any errors are found this will allow your computer to attempt a fix of the broken drive.
Restart your computer after the disk fix has been performed, and attempt to run your Windows XP setup again.
You should have no input while the chkdsk utility is in progress any input might further damage your computer and hard drive
Replace your hard disk if the setup fails with the same message. At this point your hard disk is more than likely broken and needs to be replaced.
Jun 25, 2013 | Dell Computers & Internet
Not seeing new hard disk or reading XP cd-rom
It can use any 31/2" IDE hard drive. 30 Gb should be OK
If the BIOS cannot detect the hard drive or the CD drive then the drives maybe faulty or the disk controller in the computer is faulty.
Apr 29, 2012 | IBM ThinkPad A30 Notebook
Stop c0000218 registry failure
This will sometimes happen with a Windows XP installation when either the hardware in not compatible with the operating system...or the hard drive is damaged.
Use the recovery console to confirm that the hard disk or file system Is not damaged loadTOCNode(2, 'resolution'); Important We recommend that only advanced users or administrators use the Recovery Console.
Note Only the Administrator account can access the Recovery Console.
  1. Start your computer from the Windows XP CD drive. If prompted, select any options that you must select to start from the CD drive.
    Note To start your computer from the Windows XP CD drive, your CD drive or DVD drive must be configured to do this. For information about how to configure your computer to start from the CD drive or DVD drive, see the documentation that is included with your computer or contact the computer manufacturer.
  2. When you are prompted to select Repair or Recover, press R. This starts the Microsoft Recovery Console.
    Note You may have to enter the number to specify the Windows XP installation in the hard disk.
  3. When you are prompted, type the Administrator password. If the Administrator password is blank, just press ENTER.
  4. Use the chkdsk command-line tool to examine the hard disks. At the command prompt, type chkdsk /r, and then press ENTER.
  5. Read the results, and then take any steps that you must take to complete the process. For example, you may be prompted to run chkdsk /f to fix certain problems.
  6. Restart the computer, and then try to run Setup again.
May 23, 2010 | Dell Latitude D600 Notebook
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
Apr 27, 2010 | Microsoft Windows XP Professional With...
C0000218 Registry File Failure on Fujitsu Laptop
Chances are when you reinstall Windows Xp you will lose your data.
You can recover your data by removing the hard drive from your laptop and plug it into an USB hard drive adapter and connect this to a working computer's USB port. This computer will see this as a external hard drive and you will see the various folders and files.
Copy and or burn your data folders and files to a CD.
Then put the hard drive back into your Fujitsu reinstall Windows XP.
Jul 12, 2009 | Fujitsu Computers & Internet
Need file asms to complete installation
The problem is some files in your installation cd cannot be read anymore.
Options:
1. When the error appears try to redirect the wizzard to the directory of your CD ROM and locate the file.
2. If you have back up copy of your xp cd use it to replace the xp cd you are installing when the error appears.
3. If you have a copy of your xp installer on your hard disk re direct the wizzard to that directory.
Apr 27, 2009 | Microsoft Windows XP Professional
Computer is not booting up error code c0000218
You get this message from a corrupt or damaged registry or corrupt or missing drivers, or both. Unless you have made a full backup of the operating system and data, without the XP disc I don't know of any way you can fix this. See if a friend has the same operating system disk. If all else fails a reputable repair person can solve this.
Good Luck
Mar 21, 2009 | Dell Inspiron 8600 Notebook
Xp pro repair/reinstall problem
check the connection of your hard disk, its properly conect or not
change the cd of windows and check it,
Sep 28, 2008 | Maxtor Hard Drive
C0000218 (Registry file failure)
Windows cant access required registry files
if you have a xp cd, put it in, start the setup, and enter repair console.
In repair console you should see a
c:>
prompt, type cd windows
cd repair
copy *.* c:\windows\system32\config\
type exit after files have been copyed, overwrite if asked.
type exit
restart pc and try to start windows if this fails
go back to xp setup and perform a repair installation.
Mar 27, 2008 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
153 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
