Question about Nokia 5310 Cellular Phone
My cellphone is automatic shutdown when i open it! before this i think i have passed a something that so very big memory and received on my receive files. that the start my cellphone is automatic shutdown after a few seconds. sorry guys for my sentence and my grammar i am a filipino so help me God bless..
    Sniper:
  • 91 Answers
You need to reload a firmware on your mobile , you need to get it to a service center.
Posted on Nov 05, 2010
The equipment shutdown automatically and do not turn on i veryfy the fuse is good
Does it click when you press the power button? If so, and the fuse is good, could be your power transformer. There is a thermal fuse inside of it that can open and cause a no-power situation.
Apr 29, 2013 | Sony STR-K790 AM/FM Receiver
I have a nokia 6600 , every time I will received a message I received also a messages from my out box something a download info?
Hi, i think your message memory is full,that's why you received a message to your out box,try to my advice you need to delete all you messages to your inbox or all messages memory.if ever is not work it,try to reset your cellphone.but before you reset you need to back your files and contacts you need to save all before you that reset your cellphone.reset or manual reformat *#7780# and default password nokia 12345. i hope its work.thanks :)
Aug 11, 2011 | Cell Phones
When i am starting my nokia 7210 supernova , it is only showing a blank white screen and again shuting down ???
hi there, you need to re program your 7210, due to full memory thats why your cellphone cannot initialized and it will shutdown automatically, pleas bring it to a service cellphone repair shop to re program it. thanks
Apr 23, 2011 | Nokia 7210
My fax machine is in auto print off mode how do i switch it to auto recieve mode
Hi; Receiving to Memory Temporarily You can enable memory receiving feature temporarily. Received faxes will not be printed automatically.
  1. Press [ON/OFF] to select <AUTO PRINT OFF>.
  2. ??? The fax starts receiving documents in memory.
  3. ??? To cancel, press [ON/OFF] again.
  4. ??? When <AUTO PRINT OFF> is cancelled, received faxes will be printed automatically.
good luck
Oct 15, 2010 | Canon FAX-JX200
NAD T747 Shutting Down
get a fan or do a re-stack...open the back of the e-center, Yes it will do a thermal shutdown... just like 3 mile island
Dec 10, 2009 | Audio Players & Recorders
My system shot down during a movie
The reason why your receiver is going in protect is because there is a short circuit happening. This would either be on your speaker wires, speakers or receiver itself. What you want to do to check would be:
1. Unhook all sources and speakers from your receiver.
2. Turn on your receiver and crank up the volume to maximum, if your receiver does not shutdown or go on protect then the receiver is OK. If it does shutdown and go on protect then its an internal problem on the receiver and you would need to send that over to an authorized service center.
3. Hook up a source and 1 speaker. Play something from the source or the fm tuner, Crank Up the volume to about 46 or 47 volume. If the receiver does not shutdown, its good.
4. Hook up a second speaker and repeat the process until you encounter the pop and shut down
if for example you encounter the pop on the 4th speaker, try changing the speaker wires.
5. If the receiver still shuts down then it would be a short on the speaker itself and it would need to go to an authorized service center.
Feb 23, 2009 | Onkyo HT-SR800 System
The blue tooth on my sony erricson w880i allows me to send an item but when i receive one it says my memory is full, my memory isn't full tho because when i go the the memory status thing it says i have...
Depends what you are recieving, may be wrong but I think certain items go into certain folders when downloaded via bluetooth, try moving some stuff around, also without additional memory you wont get that much stuff if they are big files
Nov 07, 2008 | Cell Phones
Sherwood rx4105
you may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
May 04, 2008 | Sherwood RX-4105 Receiver
Denon receiver shutdown
Try turning down your tone controls. Like your bass, treble, or your equalizer. If you hear too much tinny or hissing sounds, the treble has to be turned down, or turn down the upper bands controls on your equalizer to the optimun level. If you hear too much bassy sounds, your bass control has to be turned down, or the lower band controls has to be turned down to the optimun level. If you are planning on turning the volume up, you may have to turn down some of the tone controls to the optimun levels, otherwise, your receiver may shutdown, or you may blow fuses in your speakers. Also make sure you speaker wire polarity is hooked up right. Red wire on the + red terminals, and the black wire on the - black terminals. Also don't have the volume turned up too high to the point where your receiver would have clipping or distortion, or else your receiver may shutdown, or you may blow fuses in your speakers.
If this don't help, then there may be something wrong with your receiver or your speaker.
Apr 05, 2008 | Sherwood RX-4105 Receiver
Bluetooth and memory
try to restore your phone settings
Feb 06, 2008 | LG Prada KE850 Cellular Phone
Nokia 5310 Cellular Phone Logo
213 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
