The display Jumps like an old TV then stops Sometimes it kinda looks to be rolling Im not sure... could it be just the connector wire to the Motherboard or something else? Compaq Presario CQ50-130US notebook Thanks! Melanie
    Sniper:
  • 51 Answers
Hi, sounds like it could be two different things. First one is the connector to the motherboard, the other is a faulty LCD. If you took it to a local repair shop, I'm sure they would be able to diagnose it quickly for you
Posted on Nov 05, 2010
I have a westinghouse tv, model ltv27w2 and the picture is clear but it rolls and jumps constantly. any ideas on what part to replace?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 16, 2016 | Westinghouse Televison & Video
My speedometer jumps from 20-40mph when Im stopped. Also, the blinkers blink rapidly when this happens. If i turn the lights on, it revs. Doesn't do it all the time.
I would look for a broken ground wire..If its a ground wire it should be one of the big ones..Theres one from the firewall to the block..If any body work has been done or major engine work ,,sometimes the grounds are left off..If all looks good it may be in the cluster or the GEM module..
May 06, 2012 | 2002 Ford Taurus
My tv jumps with red lines while watching. JVC
It sounds like the begining of as convergence problem or cold solder on convergence board - have a tech have alook
Sep 14, 2009 | JVC AV-48WP30 48" Rear Projection...
"Rolling Screen/Static"
take the display apart and check the ribbon connectors to display unit sometimes your are lucky and find a loose plug connector
Aug 26, 2009 | Compaq Computers & Internet
Acer Aspire 5920
There might be problem with signal cable of the LCD,Had you tried with external display .If same problem with external disaply then might your graphics card problem ,if not then certain problem in signal cable or the screen itself
Mar 14, 2009 | Acer Aspire 5920-6727 Notebook
Old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Sanyo tv making high pitch noise from loose cable connector
The noise is coming from the fly-back transformer. By moving the cable connector you move the main board. Unplug the TV and remove the back. The transformer has a red wire going to a rubber cup at the top of the picture tube. Looking at the transformer you will see a dough nut shape with a metal piece going through it .. Drive some tooth picks between the dough nut and the metal core. That should reduce or stop the ringing.
Apr 21, 2008 | Sanyo DS31520 31" TV
NO SIGNAL DISPLAY
try to resolder all the loose electronic parts of you TV..maybe the cause was the loose parts.
Mar 28, 2008 | Sony KP-61HS30 TV
My eureka
The belt may look ok, but am sure it is stretched and when this happens, the brush roll won't turn like it should. Did you check the brush roll ends to see if they turn freely, if not replace it.
Mar 10, 2008 | Vacuums
TV screen jumps and rolls, sometimes won't stay on
Try Re-soldering the vertical yoke connection and the vertical output IC. Thats a common problem in that model.
Feb 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Computers & Internet Logo
Alun Cox
k24674
