Question about Broderbund PrintMaster Platinum 16
Printmaster 15 Hi, I am unable to install the program! I now have vista installed1 Val
  • ncapra Aug 27, 2008
    1. I recently had to have my computer repaired. Now I can't reload Silver 15 (XP Pro). The program will only load to 10% (font), then it stalls.
All these type programs can be used ion vista.by simply selecting help/support/ type: old programs
Vista asks to use cd - then it is installed
very much like xp whenthey did it for win 98/95
Val
Posted on Jun 15, 2008
Our business has been using Printmaster 15 for a few years now. We recently bought a new computer with windows 7. Printmaster 15 is obviously not compatible with Windows 7. I bought printmaster 2011...
You can try version 15 in compatibility mode:
Troubleshoot Compatibility
This can help with some (but not all) programs/drivers:
1) Uninstall the program if it's already installed. Then when you install/reinstall it instead of double clicking on the install file right click it and select "Troubleshoot Compatibility"
2) Then click "Try Recommended Settings" and in the next window click "Start the Program" to install it.
3) After it installs see if it works correctly. Please note - some programs may not be able to run in Windows 7.
More details about how to make older programs run in this version of Windows:
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Jul 19, 2017 | Broderbund PrintMaster Platinum 16
Installing program - BRODERBUND PRINTMASTER PLATINUM VER. 18
Check this link for the step by step way in installing this software but this is for 'PRINTMASTER' PLATINUM VERSION 17 but dont worry its just have the same procedure in installing the 'PRINTMASTER' PLATINUM VERSION 16, this is the link
http://support.broderbund.com/fix.asp?isid=44677&prog=1294820935&printer=1
Hope that helps.........
Aug 13, 2008 | Broderbund PrintMaster Platinum 16
I HAVE A VISTA 'HP' PAVILION LAPTOP. I HAVE JUST PURCHASED YOUR 'PRINTMASTER' PLATINUM VERSION 18. I HAVE BEEN UNABLE TO LOAD IT ON MY COMPUTER. I HAVE MISPLACED THE DIRECTIONS THAT CAME WITH THE...
Check this link for the step by step way in installing this software but this is for 'PRINTMASTER' PLATINUM VERSION 17 but dont worry its just have the same procedure in installing the 'PRINTMASTER' PLATINUM VERSION 18, this is the link
Trying to install Printmaster 15 for Windows 7. Is that possible?
Apparently no, it does support only Windows 98 / NT 4 / Me / XP. However, here is a thing you can try if a program cannot be run under Windows 7 because of compatibility issues, which is the case with Print Master Platinum 15. You right click on the executable file that will install the application and click Properties. Select Compatibility tab and check Windows XP SP3. If it installs do the same for the EXE file that will run the application. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 12, 2010 | Broderbund PrintMaster Platinum 15 Full...
I have vista, tried to install printmaster 15, did not completely install, and now i cannot uninstall the printmaster program so that i can try to install it again.
Here is a link to their website which describes how to manually remove the software from the hard drive. Let me know if it doesn't work and we can try some other options.
http://www.broderbund.com/c-26-support.aspx
Aug 29, 2010 | Broderbund PrintMaster Platinum 15 Full...
I purchased a printmaster platinum 12 in 2002 and loved it but now i am trying to download the software into a diffrent computer since out other computer crashed. i have my registration # but i can only...
I am guessing that your new computer has windows vista on it. That may be the reason Printmaster 12 will not install. Certain programs or their installations are not compatible with Vista.
I'm not sure what errors you are getting, and I am assuming you are running Windows Vista, so again I'm just guessing.
You could try to launch the setup program manually and using compatibility mode by following these steps:
1. Insert your installation disk.
2. Click the start button
3. Click on Computer
4. Right click on the drive containing your installation CD
5. Select Explore from the menu.
6. Find the Setup or Install file in the list.
7 Right click on it.
8. Select Properties.
9 Select the Compatibility tab at the top.
10. check "Run this program in compatibility mode for"
11. In the drop down menu select windows xp
12. check "disable visual themes"
13. Check "run this program as administrator" (if it is available)
14 click OK
15 now double click on the setup/install program.
I hope this solves your problem.
Thanks!
Nov 03, 2009 | Broderbund Printmaster Silver 12.0
Cannot install on new laptop which vista windows
Hi there, i think you have to buy the new version of it, it does not work with vista you can see it here (It writes windows 98-xp):
http://www99.shopping.com/xPF-Broderbund_Broderbund_PrintMaster_Silver_15_Jewel_Case
And
You can buy a new version here, But as far i can see in the system requirements they do not mention windows vista, so I do not know if it will run under vista??
http://cgi.ebay.com/Broderbund-Printmaster-Silver-17-PC-software-NEW-BOXED_W0QQitemZ200389004657QQcmdZViewItemQQimsxZ20090929?IMSfp=TL090929146004r3159
OR
http://www.amazon.com/Encore-PrintMaster-Silver-v17-DVD/dp/B000EGK3KM
Hope that helps
IF Not then return here
Have a nice weekend
Please rate my answer
Oct 03, 2009 | Broderbund PrintMaster Silver 15 for PC
Help
Hi there, the version you have is not compatible with vindows vista :O(
You can buy a new version here :
http://www.broderbund.com/store/broder/en_US/DisplayProductDetailsPage/productID.135272300
Hope that helps
If not then return here
Have a nice time over there
Jul 15, 2008 | Broderbund PrintMaster Silver 15 for PC
Computers & Internet Logo
885 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
