Heating & Cooling Logo
Posted on Nov 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I have an achiever 90 plus ruud, when I turn it on the flame ignites but after 3 seconds it goes out, it does this 3 times than turns off. Help?
Anonymous
Level 3:
Genius:
  • Master 1,015 Answers
  • Posted on Nov 05, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1015
Questions
0
Helped
319572
Points
3041
Are you saying that main burner is coming on or pilot /hot surface ignitor or spark ignitor ? If your induced draft motor is coming on then a few seconds later your main burner is coming on for 3 seconds and then shutting off but blower motor is not coming on I would look at flame sensor to make sure it is telling the fan motor to come on. Normally they will try three or four times and then lock out. One easy way to check blower motor is to set your thermostat to fan on. Fan motor should come on and run till you shut it off.hope this help you.
  • jybakeem Nov 08, 2010
    I have the same problem with my Ruud 90 unit. The flame sensor comes on and starts the burners and it will stay on if the front panel doors are off but only stay on for 10 seconds if they are on. I had this problem 4 years ago and the tech replaced PSI pressure switch and cleaned the flame sensor. Where can i get a PSI pressure switch, is it easy to replace (or must be done by a tech) and how do you can the flame burner?
Ruud achiever 90 plus gas furnace flame goes out after few seconds
This could be water in the hoses that connect to the pressure switch , they should just pull off and blow then out also blow out the pressure switch , this sound like a moisture problem with all the bad weather you h, check air filter is not blocked .
2helpful
Ruud Achiever 90 - Intermittent - No ignition sometimes, ignites other times and turns off after a short while, lastly can get to ignite and stay on also using technique below. Seems to work fine IF I open...
no it shouldnt have anything to do with the cover, tighten all bolts, grounds, screws that you can find. Find the flame sensor and try cleaning it and also make sure sensor in inside the flame. let me know.
Ruud 90 Plus Achiever furnace starts, ignites, runs for 30 seconds, goes out, then does it again and again.
It would seem as though you have a bad flame sensor or the ground from the burner to the ignition control is bad...
Could be the ignition control also but not nearly as likely...
Pressure switch can also cause these problems...
Bottom line is that you will need to grab a meter and try to figure out what is causing the flame to cutout...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
1helpful
Have a ruud achiever 90 plus furnace. the flame goes out after the igniter quits. any ideas
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution: You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Delayed ignition of a Ruud high efficiency upflow 90 plus propane
It sounds like the first thing to do is have burners and pilot cleaned and adjusted so ignitor and pilot flame is close to main burner ignition rail.
The "whoosh" is due to delayed ignition because the pilot flame does not come in contact with main gas.
One more thing that should be tested is the gas pressure and combustable air mixture to be sure it is correct.
It is always best to have a qualified technician do this for you, In many areas the gas supplier with check and safety test this for you.
1helpful
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
1helpful
3answers
The door, you mean the metal cover on the front? if you have the door off and push the safety switch in with your hand everything works fine? I need more info here, but if what I said is right, then the "door" isn't making good contact with the switch.
Top Heating & Cooling Experts
Paul Carew
john h
