Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Tried everything ; My John Deere L100 engine either starts roughly and or NOT AT ALL ?????? Its a 17.0 ohv Need to know what to check next; tried replaceing the spark plug/ bought both intake and exhaust rods ,gapped them as explained to myself -Still not running ; The MFG date ; 4/12/03 Even bought a new battery. My next step ? Maybe getting the specs ? Please H E L P !!!
  • 10,865 Answers
Hello. All engines need air so be sure your air filter is clean and not bogged down with oil. All engines need good spark so be sure you have the correct spark plug, properly gapped. All engines need good fuel so be sure you have a clean fuel filter and new gas. Gas that has been sitting around for over one month could lead to problems alone. IF your gas in the tank is old siphon it out and start fresh.
NOW. Get a can of starter fluid at any auto parts store and an assistant. Remove the plug and squirt some starter fluid into the spark plug hole and reinsert the plug. Then quickly spray some starter fluid into the air intake [air filter area]. Start it up. Keep it running by having your assistant continue to spray a little starter fluid into the air intake. Keep it running for a couple of minutes using this method. THIS will clear out the gunk that is causing the rough running or slow starting.
Joe
4 thumbs up please. ty.
Posted on Nov 05, 2010
John deere lawn mower
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
JOHN DEERE L100 L110 L120 L130 LAWN TRACTOR SERVICE TECHNICAL MANUAL TM2026
Mar 19, 2017 | John Deere Garden
Mower blades move but no gears forward or back, very suddenly quit.
Rex, check the drive belt,old stretched, loose, broke, fell out of position Tension er weak or seized if equipped, worn out pulleys.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tightening the belt on John Deere L110 Tractor
https://jdagccc.custhelp.com/app/answers/detail/a_id/428/~/mower-belt-comes-off---100-series
How to Adjust John Deere Drive Belt
John Deere Fail LA145
Apr 23, 2016 | John Deere L100 Series
John deere L100 cranked over...wouldn't start...out of gas....added gas, now wont crank over at all
Thou has drained the battery with all your cranking. Recharge unit and now check for spark since you have resolved the fuel delivery issue.
Mar 14, 2016 | John Deere Garden
John Deere L130 riding lawn tractor will not start what do I do?
I'm assuming the motor will crank over, but not start. Remove the air intake cover & filter off the carburetor air intake. Do you smell gas? Is gas dripping out of the carburetor? If not, spray a couple shots of starting fluid or carburetor cleaner into the carburetor air intake throat. Close the choke & crank the engine. If it starts, & stalls, repeat the process. If it won't stay running, your carburetor float jet is gummed up & needs to be cleaned. Check & clean the spark plug. Does the spark plug fire when the engine is cranked? If no, then you have an ignition problem.
Mar 05, 2016 | John Deere L100 Series
Wiring diagram
Call John Deere at Engines & Drivetrain Products 1-800-533-6446 Tell them what you are looking for . make sure you have your engine model number and serial number; off the motor shroud . also the numbers off the machine tag . Hope this helps,Grant
Aug 11, 2014 | John Deere L100 Series
Wont start light dont work
If choked off. Pull a spark plug. May be full of gas.
Apr 03, 2014 | John Deere Garden
Engine starts and runs Great. When I engage the Pto leaver on my John Deere L100 the mower fails.
at the point of lowering the pto it's trying tosuck more air to mix with the gas .you might just need to change the air filter.
Jun 07, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
165 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
