How can I sort this problem, as I don't have the original recovery CD to hand? Is there a way of going to factory settings manually?
Solution:
use the following steps below:
Start your computer with the Windows startup disks, or
with the Windows CD-ROM if your computer can start from
the CD-ROM drive.
When the Welcome to Setup screen appears, press R to
select the repair option.
If you have a dual-boot or multiple-boot computer, select
the Windows installation that you want to access from the
Recovery Console.
Type the administrator password when you are prompted to
do so.
If no administrator password exists, press ENTER.
At the command prompt, on the drive where Windows is
installed, type chkdsk /f/r, and then press ENTER.
At the command prompt, type exit, and then press ENTER to
restart your computer
But if you dont have the operating system cd, you will have to remove the hard drive connect it to another machine and perform the steps above and then connect it back and it should work.
Regards,
Yateesh Varma.
LINUX Mint, ver. 10
You will at least need a Windows installation CD to fix the BSOD 000000ED (unmountable boot volume)
This link shows how:
http://ramanathan.wordpress.com/2007/05/20/unmountable_boot_volume-error-stop-0x000000ed/
Do you by chance have a recovery partition on your Inspiron (pressing F12 when you startup up)?
There's no partition on this one, i'll have to get in touch with dell and ask for a recovery disk.
Thanks
I remove my hard disk and then connected properly as it is earliar,but the
Blue screen error code 0x00000ED is occured.also already saw the problem in my same pc more than 5 times.it will be solved by reinstaling the win xp os,but now i cant able to solve this(reinstaling the win xp os done,but problem is not solved).please send the solution for me.
thank you
use linux
