Question about Cameras
Turns on, but lens won't open fully. Turn off and lens opens up. Have to push lens back into camera to get "doors" to close on lens part.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 05, 2010
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
IT FAIL AND IT IS MAKING CLICKING NOISE WHEN I TURN IT ON. IT GIVES ME A MESSAGE "LENS ERROR "
Usually that means that you have a bit of grit in the lens mechanism and the camera recognizes that it is taking too much force to open or close. The clicking noise is the camera trying to extend the lens for use. If repeatedly switching the camera on and off fails, you are at a crossroads. You can send it to a repair facility to have the grit removed (assuming the unit hasn't be come damaged in the process). Or, you can take a substantial risk and try to "help" the lens open or close by wiggling or pushing lightly on the lens mechanism to try to loosen the grit. The risk is that you'll break the mechanism for good. I have taken this risk and won, but it's a chance you'll have to decide to take on your own!
Nov 28, 2010 | Nikon COOLPIX S630 Digital Camera
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Lens keep extended in an out
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My olympus fe-330 will not turn on
was just having the same problem the camera would not turn on... NOTHING....  battery fully charged was messing around with it opened battery door pushed in on battery while trying to turn on and it came on, guessing battery was not making complete contact added a piece of foil in door to push down on battery when door shut now working fine
Jun 17, 2009 | Olympus FE-330 Digital Camera
Lens stuck, green Power light flashes, nothing happens.
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time  you will hear a clicking noise which is normal  once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Dec 08, 2008 | Samsung Digimax S500 Digital Camera
Disney princess camera
trentshoffne,
bottom of camera open battery cover with a pen point, insert one AA battery close cover.
film door is opened with pen point left side of film door. load film & bring film leader to take up spool, close film door. rotate advance to # 1 counter on bottom.
turn camera on with sliding switch on front of camera, this opens lens cover and turns on flash .( if wanted ) second click.
at end of film roll pull rewind lever up and rotate clock-wise to rewind film.
open film door and remove film.
remember to turn camera off when not using.
Aug 05, 2008 | Photography
Kodak Easy Share Z1275 stuck lens
I have a Kodak 1275. Green light would go on the off and lens was stuck open. Now for solution that worked for me. Get a can of compressed air, like what you use for computer keyboards. Blow the compressed air all around your stuck open lens, not to fast and switch directions of where you blow air around stuck opened lens. Make sure batteries are fresh and fully charged. Tap your camera against the palm of your hand twice, not to hard or you may damage instead of jarring lens lose. Next lay your camera on a table lens facing up, push power button on so camera will try to auto focus and lens should reseat itself and lens should move freely. It doesn`t have to look dirty or dusty, little tiny particles can cause the lens to get stuck and shut off fast because it is a safety feature. If this does not work try plugging your camera into computer so the lcd screen does not try to go on , thus giving even more power to get your lens moving . Do not try to force it closed by pushing or twisting with your hand or you may cause damage that will cost as much as the camera to fix.
Jun 05, 2008 | Kodak EasyShare Z1275 Digital Camera
Cameras Logo
164 people viewed this question
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
