Question about Acer ASPIRE 3680-2022 Notebook
Laptop gets power but if you press the switch nothing happens or it does not boot.
  • Acer Master
  • 17,130 Answers
If there is power indication of the charging but the laptop does not power On at all then the fault is in the mother board, if there is no booting then check to see if the bios battery is faulty - replace.
If the PC comes on with the logo but does not boot up further then the possibility of the memory or the hard disk can be suspected. Check if you can go to the CMOS settings to see if the time has changed/ reset. If so check the battery, set time and allow it to boot , if not the memory/hard drive needs a check.
Posted on Nov 05, 2010
G4apple power boot boot up problem
If nothing happens when you press the power button then the computer is most likely out of power - plug a charger in and it should work. If it still doesn't you might want to get it checked at a service provider. If something happens when you press the power button but the computer doesn't turn on, then please provide more information, explaining exactly what happens so that I can help you.
Dec 02, 2013 | Computers & Internet
My acer Travelmate 242lc will not power on
First think , has it been dropped, jarred, banged, .....you get the idea? Does it continue to blink, the HDD? Do you see a "ghost image" in the monitor in a bright light? Do you here sounds? You say "nothing else happens", meaning the light stops blinking? Shut down, unplug, remove battery, plug in, try to boot noemally.
Nov 16, 2012 | Acer TravelMate 242LC Notebook
NOT BOOTING WINDOWS XP IN DELL INSPIRON 1545
1. Press and hold the power button for 10 seconds. If nothing happens go to the next step.
2. Remove the battery of your laptop, then plug the power cord of your laptop directly, then press and hold the power button for 10 seconds. If nothing happens I would suggest to contact your manufacturer so that they can provide further assistance.
Jun 13, 2011 | Computers & Internet
My HP dv4 1120us laptop will not power on. When I insert the power cord the led for power bolt comes on and when I press the power button the power LED flashes once and then nothing happens. The power bolt...
Sounds light a power switch short, but lets try to take the memory out of the laptop and power on the laptop. Does it boot up? if so lets try 1 memory stick at a time.
Nov 29, 2010 | HP Pavilion dv4-1120us Notebook
It is stuck on the " acer empowering people" screen it gives me options at the bottom to press F2 for setup and F12 to change boot order but when i press either of these nothing happens ive tried...
try restarting and push esc a few times should go to boot option screen ,,set it to boot from hdd,,or jus put ur cd that came with or windows disk and repair,,,,,check acer website also
Nov 03, 2010 | Computers & Internet
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
Lenovo 3000 N200 laptop not starting up, power light on
Keep pressed the power button of your laptop for about 30 seconds, the machine will power down.
--The above step may not be required as already so many days passed by.
Then plug it into the power adapter.
Switch the laptop on.
Boot in "safe mode" (F8 during boot).
This will fix any driver or some operating system issue during previous failed boot process.
Once it boots completely, do a normal shutdown and reboot your laptop in standard mode (no more F8 this time).
Now your laptop will be ready to use.
Sep 30, 2009 | Lenovo 3000 N200 Notebook
Gateway 7330GZ wont boot
for me this is the try and test situation,
try to remove ram -- look what happen. or try to turn on the laptop with the xp cd in the drive rom, there a similar case and the problem solved after i take out the keyboard and put it on again.
Jan 18, 2009 | Gateway 7330GZ Notebook
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
Acer aspire 5610
remove power supply then remove battery.
then connect to power supply and try to boot, if no luck then remove power supply and press and hold power button on laptop atleast 10 seconds then in the same postion connect the power supply.
if still no luck then you should take a tour to service centre.
For any more question just ask me.
Thanks
Iqbal
Jun 29, 2008 | Acer Aspire 5610-4648 Notebook
Open Questions:
Acer ASPIRE 3680-2022 Notebook Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
